Author Topic: Big stroke 55 cc one cylinder ICE  (Read 80761 times)
Offline AlexS
Re: Big stroke 55 cc one cylinder ICE
« Reply #180 on: February 20, 2026, 07:57:42 pm »
I am still alive, busy with side things. Camshaft need to be re manufactured. Did not recognize that the holes through the cams are not fully though. Tried to drill it with hss bit, no good, could use TiAlN coated drill but more expensive than new cams.
Also for second batch printed parts, designed with good motorcycle friend a new set of hydraulic drum pistons for his Colleda 250cc 1965? motorcycle (before Suzuki sell there own batch motorcycles same time Meguro did for Kawasaki). Interesting bike, has hydraulic drum brakes and combined front and rear brake system. cylinders rear 18,5mm front 14mm master 15mm. The original cup seals are gone and replacement very difficult to find, we found a seal for inside the master cylinder luckily! Cylinders are in good state, idea is to 3d print new AISI316 pistons, and machine them to correct tolerance (-0,2mm) and cut x-ring grooves. Already got good sizes x rings to fit the cylinder perfect at x% compression rates. Material X-rings EPDM ready for modern DOT3/4. Printing them with additional thickness and cylinder shaft 20mm length for fixation in chuck and support (picture is old, not finished).
We also look at the O-rings for the T350 these where just to large from what designed in '70 need smaller ones and free volume in o ring groove in the carburetors to seal to the intakes. Now the carbs deform.
« Reply #181 on: March 07, 2026, 08:50:41 am »
Interesting work  :ThumbsUp:  :ThumbsUp:
I like the heart you made for your Grandmother  :)  :)  :wine1:
Offline AlexS
« Reply #182 on: March 13, 2026, 01:20:52 pm »
Thank you Roger!
In meantime couple weeks ago continue with development. Calculated and drawn a harmonic intake runner with 50cc additional volume between carburetor and cylinder head. Als an replacement exhaust muffler. Muffler equipped with a J-pipe helix shape around outer surface of 700 mm length.  chamber muffler one for expansion and other with damping material with a with a continuous perforated tube through the second chamber.
I have no photo at the moment on this pc, but is looks strange but technical would do a good job on reducing sound on 1750-2200 rpm range. I aspect cost on printing higher. More when things are final, to be continued.
Offline AlexS
« Reply #183 on: May 26, 2026, 10:40:15 am »
Hello, last days continued with machining modifications cylinder head and new cylinder. It is still good temperature in the garage to work with the machines instead of doing work outside.
Cylinder
Outer surface of 2nd cylinder has same amount of cooling fins but now equal positioned, so equal thickness remained on top an bottom side. But the cut is a couple millimeter deeper compared to old cylinder so now the thickness from cylinder bore to cut of fin is 3 mm instead of 6 mm.
The cylinder need on both sides for fixation cylinder head and bottom side to crankcase m5 threaded holes.
Cylinder head
The current old exhaust valve seat does is not fitting with new tight bronze valve guide. Previous I had to re cut the seat when installed to be able that the seat and valve seal. But now there is to much of concentric offset with new valve guide. Previous guides was drilled an a slight angle, something like that the intake does not need replacement only fine grinding to clean valve to seat contact area.
So for that plan was to make new exhaust valve seat of GG25 that laying around of cylinder made of 2017. What I understand is that cast iron is much beter material for exhaust seat than silver steel that I used previously. Resistance to heat and little bit of self lubrication and demping of valve motion.
Fist cut was main 45 degree angle, width of seat area is 2mm. After that I machined a 60 degree angle on inside of the seat to reduce the main sealed seat width to 1mm (Difficult to see in picture 4).
New seat pressed in the cylinder head. And grinding the valve and seat to try to proper sealing. Also did a fine grinding on intake valve. Both valves showed in my eyes proper shiny surfaces for silver steel valves.
I had plan to replace the exhaust valve from silver steel to cut from and Peugeot 206 intake valve laying around on the work bench, but I think it is to difficult to reduce valve stem diameter to good cylindrical shape. These might be hardend, machining the outer diameter of valve head was already tough. I will first run it with new valve seat.
Offline AlexS
« Reply #184 on: May 29, 2026, 10:26:35 am »
Cylinder head
Valves installed into the head. First photo, maybe difficult to see, t
the offset intake manifold through the head and at position to entry intake valve runner area.The offset settings of milling 11 mm hole was 2.5mm on x position to the left side an 1 mm y position lower.
Both valves moves smoothly while installed in bronze guides, on top of each valves m5 thread cut for fixation with two thin nuts.
Previously I tried different valve/spring fixation with simple shaft clips or c-clips. But als c-clip of exhaust came loose. I don't know how smaller model engines create for this a solution, but I think double nuts work okay. Additional could use loctite but might not needed.
Other engineering
Past months continued with CAD modeling amd engineerong with last phase of additional modifications. Oil lubrication system is mainly finalized.  Created an pressure relieve valve and paper filter housing with an flow distribution in-one part. Two spray nozzles and two seperate feed lines, both lines printed of PA12 with MFJ methode. Still details needed of connecting oil pump to crankshaft by gears and an belt. Oil sump is almost finished with pump support and oil drain
Currently busy with continue forced air cooling shrouds. Outlet positioned towards additional cooling head of cylinder head, have to come with connection to rest of engine and try to make it a stiff part.
Last parts are back covers with output shaft bearing.
« Reply #185 on: May 29, 2026, 07:38:17 pm »
Still following along  :)
I have always used what I call E clips (probably the same as your C clips) to retain my valve springs. They sit in a recess in the valve spring support so hopefully they can't escape  ::)
Offline AlexS
« Reply #186 on: June 01, 2026, 12:44:28 pm »
Thanks for following along Roger.
That is a good solution the e clips does not come loose, would remember for other designs.
« Last Edit: June 03, 2026, 03:07:13 pm by AlexS »
Offline AlexS
« Reply #187 on: September 01, 2026, 09:47:45 pm »
Hi there! It is been a time ago last update. In meantime continue with developing to final preparation 2nd production of parts.
Forced Cooling
Created an forced cooling with a mixed flow impeller. Powered by gear and belt from the balance shaft. Inlet to avoid that fingers can reach impeller.
Lubrication
Lubrication force feed by a GY6 trochoid pump. Aluminium pressure relieve valve and paper filter housing. Spring tunable 2-4 bar oil pressure. Nylon glass MJF printed feed lines. Green line feed piston lubrication/cooling. Blue big end rod.
Exhaust Muffler
Designed an 2 chamber muffler. Larger volume than current one. First chamber is an expansion chamber, second go through with perforated pipe chamber filled with wool. Before gas enter the muffler there is a J pipe intersection of 700 mm length around the muffler. Effecting 1750-2250 rpm range.
Inlet
Same range as the new inlet with Helmholtz Resonance Chamber of 120cc volume.
Most parts are ready. Only have to find a solution for rear cover to crankshaft output support bearing, with an spanner for the oil pump belt. And add material to oil sump so engine could better fixated in an additional frame.
« Last Edit: September 01, 2026, 10:11:49 pm by AlexS »
Offline Minh Thanh
« Reply #188 on: September 07, 2026, 01:37:57 pm »
