Author Topic: Rusty restoration requiring reverse  (Read 4608 times)
Offline Sanjay F
Re: Rusty restoration requiring reverse
« Reply #30 on: July 17, 2026, 08:49:41 am »
I was thinking about the drill shanks method, I remember reading about it on someone elses build on the forum - I was wondering what the best method in general is for doing this type of thing; it's something which I have messed up in the past  ::)
Thanks all  :ThumbsUp:
Offline Sanjay F
« Reply #31 on: July 17, 2026, 09:12:54 am »
I think I'm having a 'moment', I have put 2 drill bits through, but its the narrower side of the taper which I need to machine therefore I will have to lift that end to the appropriate angle to machine (once I've worked it out!) - is that right?
« Reply #32 on: July 17, 2026, 09:22:10 am »
Yes. Pack the drill supporting the small end up by half the diameter of the difference in end diameters.
Or put a smaller drill in the large end that is smaller by the difference in the two ends.
Just depends if you want to faff about with angles or working out packer thickness or drill diameters :LittleDevil: But as the end diameters are not critical you could just cut to a near enough angle and then when it comes to rounding just feed in until the cut is tangent to the straight side.
« Last Edit: July 17, 2026, 09:27:15 am by Jasonb »
« Reply #33 on: July 17, 2026, 10:02:49 am »
Several shots in this album showing links with bosses being machined by screwing to a plate on the rotary table. All rounding, boss forming and edges done on that plate. Could even make use of the sides of that 10mm cutter which are probably still sharp ;)
https://photobucket.com/share/5463ef49-2f82-4c40-bea4-5c978d6b1ede
All manual work, only the last two images of some larger metal master patterns were done on the CNC
Offline Sanjay F
« Reply #34 on: July 17, 2026, 10:09:29 am »
They look very nicely made 👍
I’ve scribed the angle onto the piece and it’s approx 4 degree angle, I just want both sides even and I may not cut down to the line to give myself some wiggle 🙂
EDIT: about 1.6 degrees
« Last Edit: July 17, 2026, 10:18:20 am by Sanjay F »
« Reply #35 on: July 17, 2026, 10:47:01 am »
I agree with Jason it could be difficult to calculate but there is no need: If the bigger end diameter is 1/8" bigger than the smaller diameter it needs packing up by half of that so  1/16".  If you are poking drill shanks in the holes then the drill for the small hole should be (using those measurements) 1/8" larger diameter than the one you poke in the smaller hole.
Edit: Assumes the holes are the same diameter other wise you need to take the different hole diameters into account ::)
« Last Edit: July 17, 2026, 10:50:33 am by Jo »
Offline Sanjay F
« Reply #36 on: July 17, 2026, 11:42:24 am »
I think I'm good for some rotary table action, the 2 sides are not quite even and I'm 4 thou under on the bigger side, but like Jason stated, this is not a critical part.
Next important part is not to cut into the tangent section - I'm particularly bad at that so will leave some over for filing  :)
Offline Sanjay F
« Reply #37 on: July 17, 2026, 01:54:09 pm »
So far so good, I might take out the majority of the centre section whilst I have the larger cutter in place
Offline Sanjay F
« Reply #38 on: July 17, 2026, 07:03:07 pm »
Here it is........the 1st component
A couple of things I noticed, the position where I lower the the mill before making a rotation has a slight indentation, I rubbed this off using emery, more annoyingly however, the bosses are not quite central around the holes. I centred the RT using a coax indicator, then centred the piece using a pin gauge, so not quite sure why that is?
There are a few pieces similar to this one to make, so good to get this one done
A couple of things I MUST remember is that engine has the expansion link hole on the opposite side so as Jason described it earlier, I'm making a mirror image, not sure how many ot how this impacts the individual parts yet. Also the expansion link hole must be to fit this engine not the Stuart no.4  ;D
« Reply #39 on: July 17, 2026, 07:45:43 pm »
Your indent is most likely the tool flexing, assuming the end is having to do some cutting when you lower it.
When I round over the end of links I tend to lower the cutter first to full depth while it is clear of the work and then put cuts on by moving the work towards the cutter so cuts are full depth and of ever decreasing radius. Sounds like you are positioning teh cutter at final radius and then making a series of cuts getting lower with each one.
I've got a couple of bits to round over tomorrow or Sunday so will take a few extra photos.
Check that the diameter of your screws holding down the work are a good fit in the hole, a typical clearance hole may be too large. for example M3 cap heads tend to measure 2.9mm dia.
Offline Sanjay F
« Reply #40 on: July 17, 2026, 07:58:26 pm »
Yes I was placing the cutter at final radius and then making a series of cuts getting lower with each one, so next time full depth and and bring the radius in :ThumbsUp:
I made the securing bolts 2BA and 4BA and the unthreaded sections 3/16" and 9/64" respectively - maybe I need to make them a tighter fit next time........... I'll make a new set as I'll need a new setup for the suspension rods which I'm about to make next.....
« Reply #41 on: July 17, 2026, 08:06:29 pm »
Does your rotary table have a hole in the center? If so, you can use that to center the jig. Make the hole that the part screws into go right through the jig, and make a bushing that screws into the hole from underneath. That way the jig self centers on the rotary table. The hole through the part has to be a close fit on the screw for that to work - I make bushings that fit close on the screws and a close fit in the hole in the part. Still can be slightly off given the inevitable wobble of the screw in the holes, but it gets you really close with no effort. When you centered the part with a pin gauge, were you touching the pin to the screw head? If so, that could have been the issue - off the shelf socket head screws are notorious for having the heads a little off center due to the way they form them.
Offline Sanjay F
« Reply #42 on: July 17, 2026, 08:45:00 pm »
Here is the sequence I used to centre the RT and work.
RT table centred using coax indicator
I made the screws you can see on the table (just checked the are a pretty close fit)
Fixed the work to the jig securely at both ends
Removed the screw from one end and lowered a gauge pin into the work
Clamped the jig down
Replaced the screw
I didn't follow/visualise what you were saying about the bushing and screw from the centre of the RT. I don't know if it makes a difference but the centre of the RT is 2MT and sometimes I centred the table by using a 2MT arbor and dropping it into the centre hole before clamping - the quick way?
« Last Edit: July 17, 2026, 08:56:38 pm by Sanjay F »
« Reply #43 on: July 17, 2026, 10:40:38 pm »
Here is what I was trying to describe (badly). On the bottom of the jig holding the part, I drilled/tapped a hole and threaded in a screw holding this bushing:
The bushing is a close fit in the hole in the center of my rotary table. On top of the jig the hole comes through, and is threaded right through:
The two outer screws/t nuts fit into the t-slot on my table, for easy mounting in place. I just used this jig the other day (have several set up like this). The part was bolted down, with more bushings to fit closely on the screws and also in the holes in the part. This way the hole in the end of the part is centered on the rotary table. No need to use an indicator for anything.
I lowered the cutter down to be just past the bottom of the part, and made a number of passes, moving the table over a bit each time, till the diameter of the end of the part was what I wanted. No plunge cutting.
To mill the area up in the recessed portion that was left uncut in the previous photo, I raised the cutter to that height and made more gradual cuts till the diameter matched what was done the first time around:
For each of these steps, to cut the other end of the part I unbolted the part from the jig, and turned it around so the other end was at the center of the rotary table. No indicators needed anywhere, very quick to set up and go.
Hope that is a lot clearer?
Offline Sanjay F
« Reply #44 on: July 17, 2026, 11:40:28 pm »
Right, got it thanks, that is neat  :ThumbsUp:
How big is the piece in you pictures, the hole through it and the hex screw? The part I was making today had a 5/32" and 3/16" holes so was wondering about the bush and appropriate screw size  :thinking:
