Finish - are you using any cutting lubricant?What was the depth of your finishing cut?For removing the tool marks, have you tried draw filing?Your cutter is close to 1/10 of a foot in circumference, giving a speed of around 85 ft/min which is fine for an HSS tool on mild steel. You could go a little faster.
On a shape like that I'd be tempted to turn the round ends first, then taper in till the sides come up tangent. Easier to get the sides to match that way. Lots of ways to do it.
