It's been ages since I tapped a hole in cast iron but breaking a tap in some sticks in my mind vividly (the only tap I can recall breaking). How tricky were the M1.6 holes and do you have any general tips for threading CI? I have that almost complete cast iron pig that I'll be using to make various parts in future.
Quote from: PaulR on January 04, 2026, 08:21:39 pmIt's been ages since I tapped a hole in cast iron but breaking a tap in some sticks in my mind vividly (the only tap I can recall breaking). How tricky were the M1.6 holes and do you have any general tips for threading CI? I have that almost complete cast iron pig that I'll be using to make various parts in future.Hi Paul, a workaround I have seen quoted is to drill and Loctite in a brass plug which then can be tapped. Less worry about breakage and if it goes pear shaped the plug should be more easily removed to try again. Of course use depends on the clearance around your tapped hole.
Similar to the above, I sometimes use the brass plug method for small tapped holes in tricky materials, I often use M1.2 & M1.6.The difference with my method is that I make the brass plug with tapped hole already in it using the lathe, then loctite it in place. Much easier than tapping it when fitted.
I don't do anything special when tapping cast iron to what I do for any other holes. I always guide the tap while the drill is still above the hole, nothing fancy just a piece of steel rod drilled one end with a ctr drill and a point turned on the other. Held in the drill chuck it guides the top of the tap while light pressure is applied to the quill.
That end gets used for taps that have a small ctr hole in the end which you tend to find as the size gets bigger.
