Author Topic: My new project ...Small diesel engine .  (Read 20456 times)
Offline Minh Thanh
Re: My new project ...Small diesel engine .
« Reply #30 on: August 18, 2025, 05:23:24 pm »
Thank you !
  Hi All !
An update!
I'm sorting out, thinking...everything related to the model engine - more crazy than I know how to do it...,
 So progress is a bit slow
Some pictures...for now
« Reply #31 on: August 18, 2025, 05:35:58 pm »
It looks really nice, Minh!   :ThumbsUp: :popcorn:
You must be getting close to a first run?
Offline CI
« Reply #32 on: August 18, 2025, 05:38:58 pm »
It looks great !
Offline Minh Thanh
« Reply #33 on: August 18, 2025, 05:56:54 pm »
Thank you Kim !
 Yes, just water pump and fuel tank and the engine is done
Some tweaking and excitement for ...
It looks great !
  Thank you !
« Reply #34 on: August 18, 2025, 07:05:22 pm »
Looks great  :praise2:  :praise2: good luck for the first start  :)
Offline Minh Thanh
« Reply #35 on: September 11, 2025, 04:58:57 am »
Hi All !
 Update..
just a notice .
The engine is done and it runs but not good .
I am working on the injector issue
With this engine I tried to limit the fuel flow to the smallest possible (smallest I can do - for now,..future = unknown  :facepalm:) by making the pump cylinder diameter 1.75mm so I am trying to solve the atomization and have some improved
I will update with pictures and video when everything is done, about 1 week from now
« Reply #36 on: September 11, 2025, 06:51:35 am »
I wish you all the luck with your endeavors and hope for a satisfyingly result.
I know it is not easy - but as you are one of the few I know of, who have made running Model sized Diesels Engines that runs  :praise2:
Per           :cheers:
Offline CI
« Reply #37 on: September 11, 2025, 10:56:32 am »
It is quite a challenge, no doubt, to get an engine like that wrapped up.
Best of luck on it; I am sure you will prevail in the end.
Offline Minh Thanh
« Reply #38 on: September 14, 2025, 12:47:46 pm »
CI , Admiral_dk , Thank you !
An update:
The engine ran pretty good and,,..suddenly lost compression
I checked and the condition is the intake valve is not sealing - This is the first time I have encountered this condition  :facepalm: :hammerbash:
I will rebuild a new cylinder head and new injector with a little change....which i think would be better , and it will be the standard size for my other projects
Offline CI
« Reply #39 on: September 14, 2025, 02:22:24 pm »
To get an engine of that complexity to run in any fashion is a significant achievement.
I hope to build a diesel one day, and so it is good that others can perhaps define the difficulties involved.
« Reply #40 on: September 14, 2025, 08:50:34 pm »
Looks like you need to change Gasket Material  :o
Great to hear that it ran well just before the mishap  :ThumbsUp:
Per           :cheers:
Offline Zephyrin
  • near Paris, France
« Reply #41 on: September 14, 2025, 09:19:05 pm »
how come there is so much soot in this combustion chamber, certainly no good for valve sealing...
but I'm sure you'll manage to get it running, apart from you, very few people can do it!
Offline samc88
« Reply #42 on: September 14, 2025, 09:29:58 pm »
Congratulations on getting it running, Im sure you will sort the teething issues out swiftly. Are you running on pump diesel? Not quite the same but when running my no.12 stove on diesel it is much sootier than if burning parrafin/ kerosene, would the fuel make a difference in this engine with sooting up the valves?
Offline Mike R
  • Ottawa, ON
« Reply #43 on: September 14, 2025, 10:45:34 pm »
Congratulations on a running engine, working through the issues is all part of the fun. Looking forward to hearing more about this engine from you.
Offline AlexS
« Reply #44 on: September 15, 2025, 09:10:49 pm »
One step further!
Maybe you can make a head gasket with a sheet of CNAF. Resistance to temperature range up to 400 deg C or higher. CNAF include NBR material resisitance to oil/fuel and have aramid fibers for strength. Pressure sealing around 70-150 bar.
