Help! > Machines, Tools and Fixtures
Bending Eccentric Rod
PaulR:
I filed some scrap brass to 2.5mm thick, thinking a softer material would be less likely to leave a mark, and very slightly rounded the edges. The bending was easy, and the result seems accurate enough. There's a slight crease on the inside of each bend but that will come out with a bit of sanding.
Thanks Jason :ThumbsUp:
PaulR:
--- Quote from: internal_fire on June 05, 2026, 01:36:29 pm ---
--- Quote from: PaulR on June 05, 2026, 12:01:36 pm ---I'll do some experimentation first :D
--- End quote ---
I recommend that you round the inner edges of the flat material. Otherwise it is likely that an indentation mark will show up at each end of the jog.
Gene
--- End quote ---
Thanks, I've learned the hard way - next time I will!
Sanjay F:
It's still worked out well, I had to do the same operation for the first time on the flame gulper I made a last year
Navigation
[0] Message Index
[*] Previous page
Go to full version
