Help! > Specific Engine Help
Help finding the original dimensions for the Fowler BB1
<< < (2/3) > >>
Jasonb:
I mentioned the shortcomings of the Haining Darwings as the OP said he specifically wanted original sizes and should therefore be wary of the Haining drawings he says he has.
Compared to the A7 Fowler that I built which is very true to the original Hainings engines are a long way off . I do have a set of Superba castings aging and having started to look at the front end and redrawing it as I not finding a single part that did not need alteration lost some interest.
I suppose it depends what the individual wants, myself I like a bit of correct detal where possible. These days with most of us having far better equipped workshops and research just a click away you don't have to settle for building to a 60yr old desing.
crueby:
You may also want to check out the Traction Talk Forum website, lots of people there with a mix of real and model traction engines and information.
Jo:
The OP seems to have gone quiet. I suspect because there is no such thing as a free set of drawings available on the Web to 3D print a Ploughing engine.
I would start with a basic Farmer's traction engine rather than the complexities of a steam Plough. Try accessing "Scale model traction engine building, featuring "Minnie" available from the internet archive: https://archive.org/details/scalemodeltracti0000maso/page/n235/mode/2up
longtangerine:
--- Quote from: Jo on May 04, 2026, 05:12:44 pm ---The OP seems to have gone quiet. I suspect because there is no such thing as a free set of drawings available on the Web to 3D print a Ploughing engine.
--- End quote ---
Nope, i'm still here. I was just sleeping lol. Timezones. I don't really plan to 3D print the BB1 anytime soon actually, because what I had in mind was just modelling it in detail and leaving it as that. Yet another reason of why I chose the BB1 was because I wanted a real challenge despite it being the first of my models. I'm gonna go and check out the sources that y'all listed that i´m very grateful for, and I should also say that thanks for offering me an alternative, even if it wasn´t what I was trying to do.
Edit: Also, is there perhaps any chance you could tell me more about that book you mentioned? And maybe the drawings too, please. I need to be sure of what i'm saying when I go contact the folks over at that club, so i'd be really grateful for a bit of guidance from yours.
Thanks,
longtangerine
Jasonb:
The book Jo links to would really only be of use if you wanted to build a model traction engine, being a small model it has to have some compromises so is not a scale representation of full size but does build into a nice small model. A better book these days on making model engine is "Model Traction Engine Design & Construction" by Edward Georege but again won't give what you want.
There are two (and a bit) books that will have more information. The First is "The Story of The Steam Plough Works" by Michael  R Lane. this covers the history and production of the Fowler factory from the very early ploughing engines until internal combustion replaced the steam engine. Lots of photos and data but few drawings so again of limited use.
The other book is "Traction engine Design and Construction" and the acompaning illustrarted Supplement by G F A Gilbert but again neither have much about the BB1. There are a couple of part of the boiler and some detail of the winding drum in the suppliment but not a lot. bThe main book does have a general arrangement side view but at a very reduced size so it is hard to read whet dimensions are on the drawing.
These books are out of print so fetch a premium price. There was a reprint done but I think that is sold out too.
If you wanted to CAD model a "model" BB1 then either buying a set of scaled down drawings for teh BB1 or tracking down back issues of Model Engineer Magazine would give you the drawings for that but as I said it is not a totally true representation of full size.
Which leaves the Fowler archive at MERL that I mentioned earlier. The two drawings at the bottom would be of most use. One is the same general arrangement but will be at a much larger size so you can read what is there and will have to take other sizes off the drawing which is not ideal but about as good as you will get unless you can measure an actual engine. The other drawings listed will give good detail of specific parts but not of all the engine. so a lot of web searches for images and do what you can
https://merl.reading.ac.uk/wp-content/uploads/sites/10/2017/04/BB1.pdf
As an idea of what these general arrangements look like this is one of the larger "Superba" ploughing engine and that is an original Fowler works drawing.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
