Model Engine Maker
Supporting => Boilers => Topic started by: doubletop on May 25, 2020, 08:10:11 AM
I’m making a small wobbler engine and boiler for my granddaughter The boiler will be horizontal made from 16 gauge 2.5” copper tube about 7” long. It will be methylated spirit fired and is only going up to 25psi. Pretty much Mamod style. I want to put 2 or three stays in in the end plates. The smallest diameter copper rod I can get is 1/4”, I can’t find small diameter bronze either. Monel is out of the question.
So what about stainless stays? The thermal expansion (Thermal Expansion (10-6 in/(in oF))) is 9.8 for copper, bronze ranges from 9.0 to 10.2 and Monel is7.8. Whereas stainless 316 is 8.8.
I would plan to use 3mm or 4mm stainless threaded with bronze bushes and silver soldered, however, I don’t think I’ve seen stainless stays proposed in any boiler design is there any reason for this?
Your local hobby shop might have a KS metals display that has copper rod in 1/16, 3/32 or 1/8 ??
Mark
Mark
Good suggestion but I've gone through all the NZ hobby shops that come up in Google and as far as their online inventory shows they all seem to have rod in brass aluminium and piano wire but not copper.
Worth a call maybe? Might just not have everything they have on their website, have seen that before.
Mark
What about using copper wire? :thinking: Your local electrician should have scraps of various gauges of single conductor wire.
What about bronze welding (brazing) rod? :thinking: Your local welding shop should have some as small as 3mm.
I've used both as stay material in small boilers (and a few large ones.)
Over here copper rod is available on Fleabay. Are you trying to buy imperial sizes? Try quoting metric sizes.
Surprisingly, stainless steel is not suitable for boiler work, because of corrosion problems.
This is true for every grade of stainless steel with the exception of duplex stainless steel.
See:
http://www.wirralmodelengineeringsociety.co.uk/Articles/DuplexSteelBoiler.pdf
http://www.smex.net.au/Store/Store_AALS-Codes.php
Cheers Dan
See:
http://www.wirralmodelengineeringsociety.co.uk/Articles/DuplexSteelBoiler.pdf (http://www.wirralmodelengineeringsociety.co.uk/Articles/DuplexSteelBoiler.pdf)
http://www.smex.net.au/Store/Store_AALS-Codes.php (http://www.smex.net.au/Store/Store_AALS-Codes.php)
Cheers Dan
Very interesting write-up on the duplex steel boiler!
Now you mention that I know that's the case. There's still a major debate going on even about duplex boliers. (Promise I'll wake up soon)
Good idea but, as you know, getting Ebay to deliver is a bit of a problem at the moment
Good idea, I'll be calling the BOC depot later today, They are only about 15mins from the house.
Thanks for your input Team. Some great suggestions, and confirmation my question was a bit dumb.
Rather than longitudenal stays, could also do ribs on the inside of the endcaps made from copper sheet stock and silver soldered inside the caps. Bit fussier to fit than stays but not bad.
(https://i.postimg.cc/Wzwd6DfY/IMG-5201.jpg)
1/8" bronze rods now on order from BOC ;D. Delivery tomorrow, but most likely it won't be. No problem though as I can now move on knowing that particular problem is solved.
Thanks again
Another great suggestion but I would be concerned that they could fall off when soldering the end caps into the main tube. I don't have gas welding gear to localise the heat so a lot more heat required on the interface which would migrate to the center of the end plate.
Thats where the different grades of silver solder come in handy - do the inside parts with the 'hard' grade, then the final assembly with the 'easy' grade which takes a lower temperature. I usually put a small brass screw into the rib from the outside just in case too!
The says will work fine, just throwing out another option. :cheers:
I had considered different grades of solver solder but if using a propane torch the heat required to bring the main, double thickness, joint up to temp will spread to the centre of the end plate and could be high enough to release the high temp solder. After I posted my comment it did occur to me to flange the stay and use a couple of rivets to hold it in place and then solder it up.
BTW did you post your boiler build? I see you are using a central flue tube, what burner do you plan to use? Its been a few years since I did small boiler builds and I'm catching up.
The heat will spread from where you are heating, but it will always be hottest where the flame is aimed. For a copper boiler the size of yours, a propane torch like a handheld tank is not usually enough to heat it fast enough, the copper is so good at wickng it away. Years ago I invested in a larger torch, like the Sievert brand, others are out there, run off a 20 pound grill tank. The larger burner nozzles can get the bigger mass hot quick enough to silver solder before the flux burns off. If it can't do it in five minutes or so, the flux will be burned off.
I have build threads for several boilers, in the vehicles and models section. Mom st recent is for a Marion shovel, before that the one for a Lombard hauler.
Hi Pete,
Missed this, could of sent you some from this,
Didn’t measure but they are about 3 mm, I scored 4 lengths 800 mm long......well you never know when it will come in handy right? We had a new power supply run in for the plant, so asked very nicely if I could have a couple of off cuts to make rivets, no problem, would you like more.......I figured that the 3 or 4 meter lengths might be a bit excessive!
Hope all is well with you & the family.
Hi Pete,
Kerrin
Thanks, a perk of working in the power industry? I guess there would have been a few raised eybrows if you tried to walk 4 meter lengths out of the gate.
All is well down here thanks. Things are getting back to as normal as they can at the moment. I trust you are all OK?
How does the brazing rod hold up with regards to dezincification? Typical rod may be 50% zinc which is more than brass at around 40%. Compare that to say Colphos 90 bronze which is only 4%, surely the brazing rod will also suffer.
Probably OK on a low pressure seldom used boiler like this but would not suggest it for anything with higher pressures.
Hi Peter
Looks like your sorted with a Bronze stay:- just wanted to say you have to be careful putting stainless in a boiler I found this out the hard way I made the regulator spear for my simplex out of 303 stainless after 12 months the point had eroded away and the regulator wouldn't seal 303 stainless has a high iron content I replaced with 316 stainless a marine grade its been in for over three years now and still going strong.
I'm currently fitting the regulator to my Crab project I'm using a ball valve again 316 stainless 3 times as costly as brass or other grades of stainless but I know it will do the job.
Stew
Jason
The brazing rods I have on order are Manganese Bronze
Stew
If I had used stainless it would be 316. Here is the ball valve regulator in my Dart, again 316 stainless. The difference being that a regulator is not structural. A ball valve is also unlikely to have a catastrophic failure.
(https://i.imgur.com/zh8AA8K.jpg)
Actually that one is brass, which I used as a proof of concept while the stainless one arrived.
Here's the stainless one
(https://i.imgur.com/JQpIf0C.jpg)
Thanks for the pictures Peter I’m currently fitting a ball valve regulator to my crab
:ThumbsUp: :ThumbsUp:
Hi Pete,
Yep all good here. I worked thru from home, now back at the coal face. Did manage to get some shop time in which was great!
