Author Topic: PM Research #3  (Read 2248 times)
Online Sanjay F
Re: PM Research #3
« Reply #15 on: October 24, 2026, 01:18:15 am »
If I feel myself trying to rush or just get through a part, I usually hang it up for that session. Which is what I decided to do tonight as I wasn’t really happy with my planned order of operations on the cross head anyway.
Always the best way, I've had to teach myself that too; if you don't stop at that point, the workshop demon is bound to arrive and mess things up!  ::) :D
Build is making good progress  :popcorn: :ThumbsUp:
Offline Rledoux313
Re: PM Research #3
« Reply #16 on: November 03, 2026, 02:17:20 pm »
I was able to find a couple hours over the weekend to pick away at this a little more. I was able to give the cross head another shot. This time I went for the lathe. I noticed that the boss for the con-rod is round on the drawing; I think they intend for this operation to be completed on the lathe. The boss came out pretty good this time! However I am not thrilled with the outcome of the slot for the con-rod. It is not centered very well. After moving the piece to the milling attachment I used an er32 collet to get centered on the boss. Due to the nature of the er32 I couldn’t tighten the collet. Since it wasn’t tight, I think that there’s a good possibility that I was pushing the collet out of alignment when trying to center up. I also found that the cross head hits the rail risers. I made them 1/4 instead of 3/16 so they looked the same as the rail, but this causes interference. I’ll turn up some smaller ones to rectify this. I guess that’s what I get for trying to meddle with the design!
I don’t have good service to attach photos apparently, sometimes if I go to edit after posting it works… not this time. I’ll add them soon!
Offline Rledoux313
Re: PM Research #3
« Reply #17 on: November 03, 2026, 03:55:23 pm »
Here are the photos I threatened you all with earlier.
Re: PM Research #3
« Reply #18 on: November 03, 2026, 07:42:51 pm »
I never seen pieces of Hex material used as Spacers before - but the result is convincing  :ThumbsUp:
Per      :cheers:
Re: PM Research #3
« Reply #19 on: November 03, 2026, 08:16:42 pm »
Whats the reason for the spacers? Its an independant jaw chuck, isnt it?
Offline Rledoux313
Re: PM Research #3
« Reply #20 on: November 03, 2026, 10:07:59 pm »
Yes it is an independent 4 jaw, the jaws on the skinny side of the stock just didn’t close enough to grab without packing in there. Hex happened to be what I had a couple short pieces of handy.
Online Sanjay F
Re: PM Research #3
« Reply #21 on: November 04, 2026, 05:36:50 pm »
Looking good :ThumbsUp:
Offline Rledoux313
Re: PM Research #3
« Reply #22 on: November 07, 2026, 01:53:34 am »
I was able to find some time today to work on this engine. I started out by wiping up a quick crank bearing, bolt, and remade the cross head guide spacers.
Now I’ve got something that has a few moving pieces!
Now it’s time to move onto the cylinder, I started on the inboard head. One isue with ER32 collets I’ve had is that if I put something in that goes less than halfway through the collet, it works itself loose or ends up crooked. This is worse on parts with draft angle like the cast head. To remedy this I usually stick a short piece of stock into the backside of the collet about a quarter inch to keep the collet’s clamping even. I did not have a piece of of 7/16” stock nearby. Of course I could have turned one, but an end mill works just as well as long as you’re careful not to bump the edges putting it in or out of the spindle.
With the head secured, I only did some of the cuts. I’ve got the outside diameter, mating face, and the small locating boss in place.
I got the cylinder casting into the 4 jaw, and used the tail stock quill as a visual to get it centered. This casting had the pattern misaligned very slightly so I think a visual alignment worked better than a dial indicator.
I put a 3/8 end mill into a tail stock chuck, which I know you’re not supposed to do… but easy feeding and it cleaned up the hole a good bit. I ran out of time before I was able to bore it to final size.
« Last Edit: November 07, 2026, 02:03:20 am by Rledoux313 »
Offline Rledoux313
Re: PM Research #3
« Reply #23 on: November 10, 2026, 01:30:00 am »
Tonight I got the cylinder bored out to size. Once it was bored out, I super glued the inboard head to the cylinder and finished that up. That was a a pretty straight forward set of operations that the pictures explain well enough I think. The inboard head is still glued to the cylinder, I figure there is no reason to separate them until I have the three holes drilled for mounting it to the base.
Online Sanjay F
Re: PM Research #3
« Reply #24 on: November 10, 2026, 10:11:40 am »
Looking very nice indeed. Have you considered if you are going to paint or leave as is?
Offline Rledoux313
Re: PM Research #3
« Reply #25 on: November 10, 2026, 02:12:35 pm »
Thanks Sanjay! I am planning to paint it. Although I have not decided what color and how much I will paint. I lm thinking maybe a deep red, but I’m not sure how that will go with the bronze castings or brass hardware. I think a darker color may contrast with those better.
Re: PM Research #3
« Reply #26 on: November 10, 2026, 08:13:55 pm »
I like the improvised depth gauge on the tailstock quill  :ThumbsUp:
Online Sanjay F
Re: PM Research #3
« Reply #27 on: November 12, 2026, 10:33:11 pm »
I stumbled across this video series on the PM Research #3, you may have seen it already? I appreciate you're near the finishing post but thought it might be of some use............
<a href="https://www.youtube.com/watch?v=2pEohbzqqXk" target="_blank">http://www.youtube.com/watch?v=2pEohbzqqXk</a>
Offline Rledoux313
Re: PM Research #3
« Reply #28 on: November 13, 2026, 12:54:33 am »
Thanks Paul! A better tailstock indicator setup has been something I’ve been wanting to do, but I only think of it when I need it!
Sanjay, I have seen that series from Keith. Before I bought the kit I watched just about every video I could find haha. Also, I wouldn’t say I’m all that close to being done! I’d say maybe about halfway.
Online Sanjay F
Re: PM Research #3
« Reply #29 on: November 13, 2026, 09:25:18 am »
Sounds like you do the same as me and trawl the web for as much info about a new project before you start!
Have you seen these tailstock DRO's - I have one on my Warco, but there are versions for mini-lathes and Myfords etc?
https://ebay.io/m/aakqiO
