Model Engine Maker
Supporting => My Workshop => Topic started by: Kegan on August 01, 2022, 07:27:35 PM
I am very hesitant to post anything as I don't know when I will get around to doing anything regarding my lathes. But I have 1 1/2 Myford ML7 lathes. I have been dreaming for years to have anything in the lathe department and now I do.
The lathes are in pieces and I need bearings and an AMCE thread tap to make a new nut for the cross slide and I need lots of time!
I got the first lathe, the complete 1, about 2 years ago. A previous owner had decided to increase the gap in the bed and lovingly cut the bed then broke out the unwanted piece. I ground down the jagged left over bits to neaten it up. This lathe is complete with a set of change gears, 3 & 4 jaw chucks and stand but no riser blocks.
The second lathe was bought on an online auction. Nobody bid against me as I don't think anyone knew what this lathe bed was and seeing that there were no other parts. I believe that the story behind the lathe is that an elderly gentleman bought it and wanted to restore it and then had a stroke and was unable to go ahead with his plans. The lathe bed has some character grooves from careless "parting off" no doubt. I shall endeavor to not commit the same "sin" I have a stand for this lathe with a set of riser blocks. The back gear for this lathe looks brand new!
Enough for now. Here are some pics
You seem to have some fine challenges there and also some good possibilities. The green Hamerite is a little bit worrying :thinking:
