Author Topic: Twin Rotary Valve Engine  (Read 648 times)
Offline Sanjay F
Re: Twin Rotary Valve Engine
« Reply #15 on: August 04, 2026, 04:02:45 pm »
Hooray, it's running! Another success, well done - these designs are getting more interesting each time  :popcorn: :ThumbsUp:
« Reply #16 on: August 04, 2026, 04:49:38 pm »
Cheers Sanjay, I think it could be made much more compact and use a lot less material though.
« Reply #17 on: August 05, 2026, 08:28:56 am »
Hi Paul,
The engine runs well. It could also be used as a pump if a water pump were attached to the protruding piston rods.
« Reply #18 on: August 07, 2026, 06:56:11 pm »
Thanks Michael, it does seem to have a fair bit of power so a pump might work. I fixed some leaks and gave it a coat of primer but it still needs some sanding around the wonky pipework  :Lol: It was running on less than zero on the compressor's gauge before I took it apart so it needs more running in. It's also got bit of St Vitus's Dance!
<a href="https://www.youtube.com/watch?v=LZ8Qu9LyJkE" target="_blank">http://www.youtube.com/watch?v=LZ8Qu9LyJkE</a>
