You will have difficulty getting a full rotation, the valve is more likely to rock back and forth. Basically as the rod movement from the eccentric gets to the top or bottom of it's movement there is nothing to say it will go over ctr and fully rotate the valve or more likely just move the valve lever back the way it came.But if you can make do with partial rotation of the valve eg a "rocking valve" then that will work with an eccentric
Quote from: Jasonb on March 27, 2026, 09:36:15 amYou will have difficulty getting a full rotation, the valve is more likely to rock back and forth. Basically as the rod movement from the eccentric gets to the top or bottom of it's movement there is nothing to say it will go over ctr and fully rotate the valve or more likely just move the valve lever back the way it came.But if you can make do with partial rotation of the valve eg a "rocking valve" then that will work with an eccentricI had a nagging feeling that might happen even though I don't know exactly why it should. I guess it'll be a complicated mix of small factors which are probably beyond my understanding I was trying to think of a way to get the valve at the far end of the cylinder and have it fully rotate...For a rocking valve I'd probably go with the 'scraps and solder' type engine I built before as it's a lot easier than making an eccentric.
The problem for Paul is that he typically builds engines of 6-10mm bore so scaling down that Lee shaft will be quite fiddly and into the realms of watch making.As for plain pulleys and belts I think some slippage is likely so timing will not remain constant.
Here is a picture of what I was describing in my earlier post. These are screenshots of the CAD model for the big Allis water pumping engine, which has a side shaft to drive the valves from the crankshaft. The side shaft needs to stay in sync with the crankshaft on that engine, so they put a crank at either end of each shaft. The cranks on one end are 90 degrees off the cranks at the other end, just like a bicycle foot pedal crank. That way it can't lock up when one goes near top or bottom center. This is two pictures, one for each end of the shafts, so you can see the 90 degree offset.
My opinion about the time consuming part: If you are in a hurry its no longer fun, which is thewhole purpose of this hobby.
Quote from: crueby on March 27, 2026, 05:10:49 pmHere is a picture of what I was describing in my earlier post. These are screenshots of the CAD model for the big Allis water pumping engine, which has a side shaft to drive the valves from the crankshaft. The side shaft needs to stay in sync with the crankshaft on that engine, so they put a crank at either end of each shaft. The cranks on one end are 90 degrees off the cranks at the other end, just like a bicycle foot pedal crank. That way it can't lock up when one goes near top or bottom center. This is two pictures, one for each end of the shafts, so you can see the 90 degree offset.Thanks Chris, I like this idea using two cranks (or eccentrics I suppose). You threw me talking about bike cranks as they're at 180 (although it would be fun trying to ride a bike with the cranks set at 90/270 ).
Quote from: PaulR on March 27, 2026, 05:31:11 pmQuote from: crueby on March 27, 2026, 05:10:49 pmHere is a picture of what I was describing in my earlier post. These are screenshots of the CAD model for the big Allis water pumping engine, which has a side shaft to drive the valves from the crankshaft. The side shaft needs to stay in sync with the crankshaft on that engine, so they put a crank at either end of each shaft. The cranks on one end are 90 degrees off the cranks at the other end, just like a bicycle foot pedal crank. That way it can't lock up when one goes near top or bottom center. This is two pictures, one for each end of the shafts, so you can see the 90 degree offset.Thanks Chris, I like this idea using two cranks (or eccentrics I suppose). You threw me talking about bike cranks as they're at 180 (although it would be fun trying to ride a bike with the cranks set at 90/270 ).Doh! You are right! Been doing steam engines too long, forgot how my bike worked!
