Help! > Machines, Tools and Fixtures
Bending 1/8" copper pipe
PaulR:
--- Quote from: Keith1500 on August 25, 2025, 01:17:04 pm ---I would bending the pipe around something that’s the right diameter help in the vice. Anneal the copper pipe first and allow for a straight bit either side of the bend that can be trimmed back to suit. You’ll feel the pipe start to roll around the “guide” in the vice. Don’t allow it to bend in one place but roll along the circumference of the bend. Don’t do it in one hit either. The pipe will start to oval. At this point stop and anneal then in a small smooth jaw vice gentle squeeze the pipe round. Work in from the straight sections as these are still round. Then continue with the bending.
If the bend is slightly in the wrong place you can “ roll” the bend along a little by adding to the bend at one end and easing out or re straightening the other, again using the small vice and multiple squeezes to keep it round.
All the pipe work on my Speedy was done by hand and likewise brake pipes on my car.
--- End quote ---
Thanks Keith, if I can get them to that standard I'll be more than happy. Need to get some random bits to practice on!
PaulR:
--- Quote from: tghs on August 25, 2025, 01:24:32 pm ---annealing is your friend along with woods metal (cerro bend) easy to turn a mandrel for the size you need.. I did get on of these a while back.. nice and small, https://www.ebay.com/itm/232496785888?itmmeta=01K3GJNWGENKE88JM09WKZ3X1K&hash=item3621e369e0:g:TtcAAOSwqfpZxEim :cheers:
--- End quote ---
Thanks for this - that bender is the mini version of my plumbing tool.
Charles Lamont:
To my mind, a pipe bender for small tube that will do a good job needs three things: a die to form the bend around, an anchor to hold the fixed end as close to the die as possible, and a former. Rather than a wheel former, which can't be got close enough to the anchor piece without being cut away like the die, my former is straight, and is pushed round by a bearing.
PaulR:
--- Quote from: Charles Lamont on August 25, 2025, 05:13:54 pm ---
To my mind, a pipe bender for small tube that will do a good job needs three things: a die to form the bend around, an anchor to hold the fixed and as close to the die as possible, and a former. Rather than a wheel former, which can't be got close enough to the anchor piece without being cut away like the die, my former is straight, and is pushed round by a bearing.
--- End quote ---
That a very nice tool (but would probably take me longer to make than the entire engine :Lol:). Still, it provides useful tips for doing it in a more ad hoc manner - thanks!
vtsteam:
--- Quote from: PaulR on August 25, 2025, 11:34:48 am ---I need to bend some right angles into 1/8" copper pipe but it's too small for my plumbing pipe bender and I don't want to buy another tool as it's not something I plan on doing regularly.
I've read about filling the pipe with water and washing up liquid and freezing it but I'm not sure that would work for this small bore. Has anyone tried it or can offer an alternative solution? Would any heat be needed during bending? It's new pipe, would it need annealing first?
(I've also read about buying soft plastic rod to fill the pipe but again I'd like to avoid the expense if possible.)
Paul
--- End quote ---
I've heard of using sand (in the case of 1/8" pipe, it would need to be fine sand) and then bending it.
The important part is that it must be capped at both ends so the sand can't move. Probably cap at one end, tap vertically on a hard surface to settle toward that end, top it up again and cap at the other end.
I would probably try it by simply squeezing the ends on 1/8" tube to cap them. Then cut off the crimped ends afterwards.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
