Model Engine Maker
General Category => Chatterbox => Topic started by: tghs on December 25, 2020, 07:07:16 PM
so, as little Xmas present from work I have $120.00 to spend at amazon,, thinking that a 1 ton palmgren arbor press might be a good shop addition.. anybody have other good tool suggestions.. In the new year I'm looking very hard at a 7 x 16 lathe (hopefully tarrifs will stop)
Well, I don't know what you have or might be in need of, or indeed what machine tools you have. $120 will get you a very high quality micrometer - can't beat having some decent metrology tools on hand.
Or - how about gauge pins / gauge blocks? Since I discovered gauge pins a few months ago, I wouldn't be without them by choice. Shars sells their stuff on Amazon (cheaper than on their own website usually).
I may go and skulk about your postings and see if I can figure out more about your current set up so that I can make more useful recommendations.
Thanks for the advice.. I'm set on good mic's, I actually ordered up the press,, in the near future I'll be doing lots small rivets and sheet metal work,, or maybe simulating rivets.. I may pick up a set of small broaches later..
Well I’ll be very interested to hear what you think about it. I was thinking about broaching today and thought an arbor press might be a good add at some point.
That palmgren ap10 is the one I got this winter, pretty good unit.
RE: Arbor press and broach. Note that you need a lot of head room to use a broach and most of the small arbor presses do not have enough room. Even the small broaches are 6 to 8" long. I have a small arbor press and I use it for pushing in bearings and other press fit items but it does not work for broaching.
I think it will fit 1/16th and 1/8th broaches,, shouldn't need anything bigger than that for the work I do.. most likely it will get used for stamping and pressing sheet metal, bearings and shafts,, If I need to go bigger for a job,, there is a large press not to far away.. (there is a lathe or two over there also)
I bought this set of broaches some time ago. about 80£ from a ME Show..1/16. 3/32. 1/8" and you get a good range of ferrules to go with them . there are 5" long and I use them in a drill press...
willy
