Great museum, and great photos! Thanks for sharing the trip with us!For that engine with the two rods to adjust the steam valve - ones like that have two stacked slide valves, one that is like the normal d valve, second has ports that control flow into the first one. Tricky stuff, made for fine control over the cutoff positions and better savings in steam. Same goal as the trip valves in Corliss engines with fewer moving parts.
Hi Sanjay, just got the new pics and the unpainted bronze engine to the left in the picture is my currant triple expansion Botan, Bertinat engine that should refinished this year ?!!!Willy
Quote from: crueby on June 14, 2026, 06:52:09 pmGreat museum, and great photos! Thanks for sharing the trip with us!For that engine with the two rods to adjust the steam valve - ones like that have two stacked slide valves, one that is like the normal d valve, second has ports that control flow into the first one. Tricky stuff, made for fine control over the cutoff positions and better savings in steam. Same goal as the trip valves in Corliss engines with fewer moving parts.Ah I see that does sound complex, I'll have to find some pictures or diagrams ......my brain has trouble visualising!
Quote from: Sanjay F on June 14, 2026, 06:55:47 pmQuote from: crueby on June 14, 2026, 06:52:09 pmGreat museum, and great photos! Thanks for sharing the trip with us!For that engine with the two rods to adjust the steam valve - ones like that have two stacked slide valves, one that is like the normal d valve, second has ports that control flow into the first one. Tricky stuff, made for fine control over the cutoff positions and better savings in steam. Same goal as the trip valves in Corliss engines with fewer moving parts.Ah I see that does sound complex, I'll have to find some pictures or diagrams ......my brain has trouble visualising! Look up Expansion Valve Gear, and Meyers Valve Gear. Here is one good diagram - click on the picture in the upper right of the page:https://en.wikipedia.org/wiki/Expansion_valve_%28steam_engine%29Also, this page at the Science Museum site has a fantastic reference for it. Its a cardboard teaching aid made long ago, if you click on the left/right arrows next to the pictures, it steps you through the sequence that the valve makes.https://collection.sciencemuseumgroup.org.uk/objects/co8033036/diagram-of-meyers-variable-cut-off-valvesChris
