Saturday I went up to Canada, met up with CNR from this forum, and we went to the show in Blyth Ontario. Great show, quite a variety of engines. Lots of traction engines, farm equipment, a dragline shovel, sawmill, etc. We were hoping the Erie B shovel from the Teeswater guys would be there, but for some reason they didn't make it. Below is a sampling of pictures from the show, starting out with a compilation of video clips:
This sign goes with the little pump running in the second clip of the video - a nifty little 'engine' that uses some of the water from the source to push water up higher that the source is using a water hammer effect. If you look on wikipedia there is a good description/diagram of how it works. Not super efficient, but it takes no fuel other than some of the water.
Some smaller traction engines were there in addition to the full size ones
The dragline - its in the video running
This was a great find for me, since I am in the middle of building a model of a similar Worthington pump!
This one is one of the smallest in the line, 3x2.75x3 (steam bore, pump bore, and stroke). Found the same model pump in one of the old catalogs I have with full specs.
