Author Topic: 1953 Ford 3 speed manual transmission  (Read 4239 times)
Re: 1953 Ford 3 speed manual transmission
« Reply #15 on: October 09, 2020, 12:10:55 AM »
It's a 3 speed forward and 1 reverse so 4 gears actually. Well not even 4 gear sets as 3rd gear is a straight connection to the input shaft.
 As far as lubrication it's like all manual transmissions, the gear oil is high enough that the gears run in it.
Offline Elam Works
  • Glen Mills, PA, USA
« Reply #16 on: October 09, 2020, 03:13:23 AM »
Someone was asking about the gear selection. While not the same model transmission, the attached photo is typical of the selector box arrangement.
-Doug
(Warner-Gear T10B)
« Reply #17 on: October 09, 2020, 12:30:27 PM »
Thank you very much for the picture Doug  :cheers:
Offline nj111
« Reply #18 on: October 09, 2020, 01:08:14 PM »
George, wonderful work (yet again!).  Also, thank you for putting it up here, it's been something a little bit different and most interesting.
Nick
Offline 90LX_Notch
    • YouTube Channel
« Reply #19 on: October 12, 2020, 03:20:08 AM »
Another great project George.  Beautifully executed.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Online steamer
« Reply #20 on: October 12, 2020, 02:58:57 PM »
Great Work.
I had no doubt that this would turn out as well as it did.
So, have you built the fully-functioning differential and rear axle with drive shaft that you need to go with this?
(Consider I just slapped myself for that comment.)
I think the Ford I drove in high school had a transmission like this and the linkage from the steering column would sometimes jam and not shift out of first gear. That's why I had to have those big Channellock pliers with me.
ShopShoe
The Chevy's would do that too...especially if it was really cold outside and the gear oil  was like peanut butter....so you learned to drive in first easy for a mile, and then shift once the gear oil warmed up....at least on my Dad's 1965 C20 pickup....3 on the tree....327 V8
Online Roger B
« Reply #21 on: October 12, 2020, 05:00:09 PM »
Excellent  :praise2:  :praise2:  :wine1:
Are you working towards the complete car?
