Author Topic: Two inch Clarkson Vertical.  (Read 16749 times)
Re: Two inch Clarkson Vertical.
« Reply #105 on: September 25, 2021, 10:19:05 AM »
Hi Terry, just seen your half wooden press design first time.
Very interesting but sure functional also.
Waiting for the next pictures of your engine.
Offline scc
  • Lancashire, UK
« Reply #106 on: September 25, 2021, 06:37:02 PM »
Hi Achim,  I needed a press for my keyway broach but could not afford one. I cobbled one together from what was lying around.  Not pretty but works well.
Pics attd of the Clarkson,    video soon,             Terry
Offline scc
  • Lancashire, UK
« Reply #107 on: September 25, 2021, 06:38:46 PM »
pics
Offline scc
  • Lancashire, UK
« Reply #108 on: September 28, 2021, 07:19:06 PM »
[youtube1]https://youtu.be/3UNqCYDZ9cU[/youtube1] video as promised
Offline mnay
« Reply #109 on: September 28, 2021, 07:21:43 PM »
Beautiful work, love the sound
Offline scc
  • Lancashire, UK
« Reply #110 on: September 28, 2021, 07:28:06 PM »
This engine has now been put on the shelf until I can get keen enough to finish it.  I still need to make and fit cylinder drains and a lube system at least.  You can probably hear a knock which cannot be "felt" anywhere, but maybe the piston touching a cylinder cover?  I'm working on the Charlesworth engine at the moment and will post about that soon.        Thanks to all who have followed this build :cheers:       Terry
Online Jasonb
« Reply #111 on: September 28, 2021, 07:54:05 PM »
Got a nice powerful sound to it. :)
Have a look at the crank pin alignment as it looks like the flywheel and flange are moving in and out as the engine rotated which could be the pin being a bit off from shaft and causing the knock. Or it may simply be you have a bit too much end float on the crankshaft.
Offline scc
  • Lancashire, UK
« Reply #112 on: September 28, 2021, 08:16:22 PM »
Well spotted......there is a bit too much endfloat,     didn't think that woul :thinking:d knock  :thinking:       Terry
« Reply #113 on: September 28, 2021, 09:43:22 PM »
Nice runner  :ThumbsUp:  but almost too big to be a model .... I'm sure it could do real work if it had to  :thinking:
« Reply #114 on: September 28, 2021, 11:45:11 PM »
Congratulations Terry! Very nice looking engine  :ThumbsUp:
Offline scc
  • Lancashire, UK
« Reply #115 on: July 24, 2023, 08:30:36 PM »
Revisited!!!    I decided to progress completion of my Clarkson having lost interest some time ago.   I have changed the con rod to one with a split big end. This entailed enlarging the crank pit.   Modified the valve gear and eccentric link, etc. Started to change the paint and then lost heart again :ShakeHead:    My problem is that it is "just" a model and not a minature of a REAL engine :shrug:
It will get finished one day...........Terry
