Author Topic: Build pictures of GB 4 cylinder overhead value engine  (Read 2548 times)
Offline gldavison
  • Tarkio, Mo.
« on: August 17, 2020, 02:49:16 AM »
Some members wanted to see a build thread on my construction of Geroge Britnell's 4 cylinder overhead value engine. I did not take any pictures of actual machining setups. So here you go with what I have so far.
This is the first group picture I took.
The con rods are bronze. I just happen to have a section of bronze bushing stock 3"OD X 1-1/4" ID left over from repairing a dozer years ago. I cut a slice off and milled to the proper thickness. Then I draw a 3" circle in cad with id of 1-1/4" and placed 4 rods and caps in that circle. The code was generated in Fusion360 and they were cut on my home made CNC router. You can see that machine here. http://www.gldpages.com/CNCRouter.htm
After they were cut out I used a rotary table to do the profiling.
The rocker arms were constructed in same manner as the rods and profiled on RT.
Here is the value and tappet cover.
And here we have the spark plugs.
This is the last group picture I took.
The timing gear cover and distributor cap were also CNC'd on my router.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline nj111
Re: Build pictures of GB 4 cylinder overhead value engine
« Reply #1 on: August 17, 2020, 08:02:14 AM »
Very nice, you are getting on well with that project.
Nick
Offline Johnmcc69
  • Erie Pa., USA
« Reply #2 on: August 17, 2020, 03:41:09 PM »
 :ThumbsUp:
WOW! Nice work!
« Reply #3 on: August 17, 2020, 06:51:12 PM »
Gary:
I like your CNC router.  What are you using to control it and what kind of travel speeds can you get out of it?
I'm currently working on a CNC router that will be similar in size to yours'.  The design for my router is very loosely based on the MPCNC and I am curious about the performance of your machine.
FYI - I tried the link on your homepage to your CNC foam cutter, but it didn't work.
« Reply #4 on: August 17, 2020, 10:08:34 PM »
That looks great Gary. Been wondering how you are doing. Pretty good I'd say.  --Tim
Offline gldavison
  • Tarkio, Mo.
« Reply #5 on: August 18, 2020, 01:07:49 AM »
Well, I guess since some fellows got me posting, I just as well keep it up until this project is finished. Today I finished the exhaust pipe flanges. Here I m profiling on the RT.
And the finished product.
Gary
Offline gldavison
  • Tarkio, Mo.
« Reply #6 on: August 18, 2020, 01:10:35 AM »
Hi Tim,
All's well here. Looking forward too Rapid City.
Gary
Offline gldavison
  • Tarkio, Mo.
« Reply #7 on: January 05, 2021, 03:56:52 PM »
Time for an update on this little engine. I decided not to make a radiator when I found this on Walmart's website. $27 and free shipping, just couldn't turn it down. It’s for a 4” (120mm) computer fan.
As you can see, there is no fill neck. So got out my radius gauges and measured the radius on the tank. Then I drew up a model in a 3D CAD program.
Machining the fill neck.
And the radius
Next we need a radiator cap.
I use coarse sandpaper to sand the paint off of the tank at the top and proceeded to a fix the aforementioned part with J-B Weld. After the JB cured out, drill a hole  thru the new fill neck into the tank. And the finished product.
I 3D printed the fan shroud.
Gary
« Reply #8 on: January 05, 2021, 08:46:53 PM »
Great conversion of the radiator - I really like the transformation  :cheers:
Have you assembled the engine yet ?
« Reply #9 on: January 05, 2021, 10:14:46 PM »
Love the look of the radiator, never knew they made ones that small.
« Reply #10 on: January 06, 2021, 02:15:46 AM »
Gary,
Glad to see that you are doing well and being productive as well. The engine looks great.
