I had noted that the Thorpe and R&B were missing from their respective tables, unless tomorrow is down as a running day
hot air engines, Stirling and vacuum engines, 2 strokes IC engines, spakies and diesel, and four strokes, with some current projects not finished.
If you made it as far as the boat exhibition and the hall with the heavy metal displays, you may have seen the small setup out back in an open field? That was me with my High Powered Rocket! We had to get an FAA waiver to fly it so we scheduled the demonstration for the last weekend.Here is my custom built rocket, nick named "Stubby" setup on the launch pad, ready for flight. She flys on a K550 motor which requires special permits to obtain.Thanks for making it all the way past the outer buildings to see Stubby fly. I know it was quite a walk. Make sure and drink plenty of water - it's hot out here and a long way back to the main engine exhibit hall.Kim
Quote from: Kim on September 05, 2020, 06:28:55 PMIf you made it as far as the boat exhibition and the hall with the heavy metal displays, you may have seen the small setup out back in an open field? That was me with my High Powered Rocket! We had to get an FAA waiver to fly it so we scheduled the demonstration for the last weekend.Here is my custom built rocket, nick named "Stubby" setup on the launch pad, ready for flight. She flys on a K550 motor which requires special permits to obtain.Thanks for making it all the way past the outer buildings to see Stubby fly. I know it was quite a walk. Make sure and drink plenty of water - it's hot out here and a long way back to the main engine exhibit hall.KimHi KimThat is pretty cool! Where was the launch site? I know that here is a local group of high powered rocket guys in the Boise area and they have a launch every fall over by Mountain Home somewhere. I have always wanted to go but have never made it. Dave
