Supporting > Boilers
Stainless Stays
<< < (2/5) > >>
Jo:
Over here copper rod is available on Fleabay. Are you trying to buy imperial sizes? Try quoting metric sizes.
ChuckKey:
Surprisingly, stainless steel is not suitable for boiler work, because of corrosion problems.
Dan Rowe:
--- Quote from: ChuckKey on May 25, 2020, 05:17:19 PM ---stainless steel is not suitable for boiler work
--- End quote ---
This is true for every grade of stainless steel with the exception of duplex stainless steel.
See:
http://www.wirralmodelengineeringsociety.co.uk/Articles/DuplexSteelBoiler.pdf
http://www.smex.net.au/Store/Store_AALS-Codes.php
Cheers Dan
crueby:
--- Quote from: Dan Rowe on May 25, 2020, 05:38:09 PM ---
--- End quote ---
See:
Cheers Dan
--- End quote ---
Very interesting write-up on the duplex steel boiler!
doubletop:
--- End quote ---
Now you mention that I know that's the case. There's still a major debate going on even about duplex boliers. (Promise I'll wake up soon)
--- Quote from: Jo on May 25, 2020, 03:46:03 PM ---
--- End quote ---
Good idea but, as you know, getting Ebay to deliver is a bit of a problem at the moment
--- Quote from: GWRdriver on May 25, 2020, 02:13:03 PM ---
What about bronze welding (brazing) rod?  :thinking:  Your local welding shop should have some as small as 3mm.
--- End quote ---
Good idea, I'll be calling the BOC depot later today, They are only about 15mins from the house.
Thanks for your input Team. Some great suggestions, and confirmation my question was a bit dumb.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
