Don't use the 0.9.8 CB files, 1.0 is the official release now.
Thanks guys.The part was created from an example CamBam, found here...http://www.cambam.info/doc/plus/SimpleExample.htmThe size is 5" x 2.375" and 1/2" thick..................I'm still curious why the motors got too hot to touch. However, I haven't done any motor tuning or checked what controls there are for setting acceleration etc., or what, if anything, I should do to optimize.I know there's a procedure for tuning the Gecko drive which I haven't done yet.
CamBam used 10,000 rpm spindle and 0.7 in/min feed rate, Little Machine Shop calculator suggests 6000 rpm at 0.7 in/min (if 2 flute/HSS end mill in aluminum) so 0.7 seems reasaonable. Also, increase the depth of cut from 0.02" to 0.022" for the first pocket.
I thought you were running something for the lathe, that looks to be a part milled out of plate
If you are using mill code then you may be better off with the X&Y motors running as they are the ones that move the most.
