Supporting > My Workshop
Getting shop together
Shiroth:
Decided to dismantle the Mill head and get it all working properly. it make quite a bit of noise when running. so might as well do it now before anything happens.
The bearings had some grease that had hardened and some things needed fixing.
The excitement to play with it makes it very hard to take my time and do it right. but it needs to be done.
Ended up making myself a little table cover for the mill after work. original plan was just to make it flat but I felt that adding the lip on the sides would help and make it look and function better. I have had a request for me to make 2 more for my dads mills.
Might have to make another one but with the lip on all sides.
Shiroth:
Been awhile since I have Snooped around on here much. Work and kids don't leave a lot of time to really play much, and when i do get to play it is spent trying to get things together for my own personal business.
I have gotten much more room in the shop a few months ago, as the Pontiac got sold. a few more toys have been added to the ever growing collection, consisting of a sheet metal slitter, an 8 foot brake, home built 4 foot brake, dewalt cordless bandsaw (Wish I got long ago), and a nice generator that i got from princess auto scratch and dent.
also built 2 4x8 work tables that can stack together to save a bit of space.
One of these days I will get around to building something, as of right now I feel that I do not have all the tooling I need. as of right now all I really have are endmills. :'(
onto the pictures!!
Shiroth:
Its been a fair bit of time since Iv lurked around the forum much.
Mostly I have just been doing other projects, but finally got started on a few Garage / Shop related projects.
The first major project included insulating the garage and removing the old insulation that was falling out all over the place, it was a terribly hot and itchy process. But it got done and was free since the semi local firehall was under renovations and I sniped a trailer load of insulation.
Second shop project started late fall and was a replacement for the old furnace. $90 in diesel a week was becoming excessively expensive so I opted to replace it with a natural gas furnace. The Furnace got installed last week as priority was to get the gas line done before the ground froze.
New belt on the drill press and put it on a stand finally. I even got to use it for the first time on the furnace mounts!
I have 4 new LED lights I got off marketplace awhile back, hopefully to be installed after I put up the vapor barrier and some plywood.
The busted up parts of the floor are on the list of to do's as well.
Far too many items have found their way into the shop over the last year, much needed sorting and organizing is required.
Looking to have the mill motor rewound for 230v from 575v and return it to its rightful place atop its throne and remove the micky mouse impersonator.
I even managed to get me a press from princess auto scratch and dent for $75
Looking back at the first few pictures of this post... so much has changed.. you can see the floor in most spots now!
***EDIT***
Forgot the pictures!!
Kim:
Your shop is looking good!
It feels great to be getting the shop in shape, doesn't it? ;D
Shiroth:
--- Quote from: Kim on January 08, 2023, 12:36:54 AM ---Your shop is looking good!
--- End quote ---
It does feel like a bit of a weight is lifted.
The flash rust on everything from the temperature changing was a huge pain in the butt.
Now to see how much it costs to keep it heated all winter.
With the old oil furnace parts and the blower motor extracted, I can build a few new toys with it.
Possibly a new diesel powered foundry and some sort of grinder for the crank and cams.
I would like to fix the leaks in my air compressor and built it a small addition on the back of the shop to clear up even more room.
Planned for later this year..
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
