Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 266039 times)
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1455 on: January 31, 2025, 06:40:26 AM »
That subassembly looks Amazing  :praise2:
Per      :cheers:
« Reply #1456 on: January 31, 2025, 06:06:23 PM »
Catching up...and wow, nice pump!  :popcorn: :ThumbsUp:
Offline tghs
« Reply #1457 on: February 02, 2025, 05:10:10 PM »
Thanks all :),, besides getting back on the duplex feed pump one of the next things will be building a modified Crueby rivet squeezer.. after some back and forth with the master himself decided one could be made to meet the needs,, small brass rivets but many.. and a 6 inch reach.. the outer stack on the boat would have been a a 6ft brass sheet rolled to size with the seam riveted every couple of inches (lots) scaling it gives me a 12inch pipe to make about 2.45" in diameter.. a big for my shop slab of steel has been ordered and the plans for the squeezer have been drawn to meet the needs..the boiler shell will also have quite a few rivets so the new tool will get a work-out :cheers:
what the @#&% over
« Reply #1458 on: February 02, 2025, 05:28:16 PM »
Thanks all :) ,, besides getting back on the duplex feed pump one of the next things will be building a modified Crueby rivet squeezer.. after some back and forth with the master himself decided one could be made to meet the needs,, small brass rivets but many.. and a 6 inch reach.. the outer stack on the boat would have been a a 6ft brass sheet rolled to size with the seam riveted every couple of inches (lots) scaling it gives me a 12inch pipe to make about 2.45" in diameter.. a big for my shop slab of steel has been ordered and the plans for the squeezer have been drawn to meet the needs..the boiler shell will also have quite a few rivets so the new tool will get a work-out :cheers:
I can't  take credit for the design of the hand rivet squeezer. They have existed in the aircraft manufacturing  world for many decades, powered ones in large manufacturing  too. Mine was based on one that was posted here years ago, I  think  it was by Florian, and he helped me make mine.
Found his original post:  https://www.modelenginemaker.com/index.php/topic,6497.0.html
« Last Edit: February 02, 2025, 05:32:40 PM by crueby »
Offline tghs
« Reply #1459 on: February 06, 2025, 06:42:58 PM »
needing to make sheet metal lap joints for the stack and boiler shell I looked about for an edge roller tool or the like that would give the shapes required,, Eastwood tools had some panel edge shaping tools that would work but not in the size needed,, they are dies welded onto the jaws of vise grips.. solution, mill my own set of dies.. tested with a vise, did a little more tweaking, they and and a big old vise grips are with a friend to get welded...  :cheers:
what the @#&% over
« Reply #1460 on: February 06, 2025, 06:56:14 PM »
Pretty slick! I've seen setups like that on car shows, but they did it with very large hydraulic presses/rollers.    :popcorn: :popcorn:
Offline tghs
« Reply #1461 on: February 06, 2025, 08:00:46 PM »
most of the stock I'll be using is .025 or less,, the test section looks ok, may need to make some "chasing" tools if it needs to be refined,, did look right past the cabinet with the rarely ever used arbor press I bought with Xmas money a few years back.. :facepalm: could mill a set dies with guide rods and a spring to fit the press.. :cheers:
what the @#&% over
Offline tghs
« Reply #1462 on: February 10, 2025, 07:21:41 PM »
waiting on stock and welding,, did more of the shop re-org,, things grouped and sorted in storage boxes,, rack made next to the mill so the spindle lock tool won't go missing,, plus spaces for often used tools,, did do some 40ME threading on the keel condenser fittings, Slim finally realized he only got a plastic trophy and not a raise,, informed he could get replaced by a robot!!! (bonus points if you know where the robot is from)
what the @#&% over
« Reply #1463 on: February 10, 2025, 07:41:38 PM »
Skutter from Red Dwarf!  Not as funny as the talking toaster...
Offline tghs
« Reply #1464 on: February 10, 2025, 11:17:21 PM »
we have a smeggin winner!!!! if you read the books you find out why there are only a few skutters (remaining) and why they avoid Rimmer :cheers:
what the @#&% over
« Reply #1465 on: February 11, 2025, 12:14:12 AM »
Didn't know that  it was books first, only saw the series. Funny show!
Offline tghs
« Reply #1466 on: February 11, 2025, 01:47:19 AM »
I don't know if the books came out first, but they explain much in great side-spltting detail.. :ROFL:
what the @#&% over
« Reply #1467 on: February 11, 2025, 01:58:53 AM »
Looked them up - the series came first. I'll give them a read, thanks for the tip!
Oh, and are the cats in the boat related to Cat from the show?!
Offline tghs
« Reply #1468 on: February 11, 2025, 02:15:27 AM »
in theory they would all be related..
what the @#&% over
« Reply #1469 on: February 11, 2025, 05:36:22 AM »
What are those interesting bits I see sprued up in the last photo, just over Slim's left shoulder?  Will they become new cast bits for Slim to inspect?
