Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 266039 times)
Offline tghs
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1470 on: February 11, 2025, 10:38:24 AM »
that was the waxes for the stack base/hinge I made before deciding to go the turn, mill and solder route!!!
what the @#&% over
« Reply #1471 on: February 11, 2025, 04:41:50 PM »
I'm curious, how much do you usually over-size your waxes to allow for shrinkage when the brass cools?
Offline tghs
« Reply #1472 on: February 11, 2025, 08:11:37 PM »
going on what I have read and tried small castings 5-7%
having a few boxes of used brass tube fittings decided that some may work as a starting point for boat fittings,, turning, sawing, milling, soldering and filing.. should be able to fit a compression ring, I cut a bevel for it.. still need to make the base flange that threads onto the thru-hull fitting..
what the @#&% over
Offline Zephyrin
  • near Paris, France
« Reply #1473 on: February 12, 2025, 09:52:55 AM »
The problem with these little compartments in the storage boxes is that I can't get hold of the little pieces inside with my fingers now - I need tweezers all the time!
What's that thing with a crank attached to the side panel of the cabinet on left of the cute little Emco SL?
It looks like a pencil sharpener, like the one in my primary school classroom?
great progress with all these intricate parts, nice to follow this build !
« Last Edit: February 12, 2025, 09:56:19 AM by Zephyrin »
Offline tghs
« Reply #1474 on: February 12, 2025, 10:38:37 AM »
about 20 years back at the university I work at had to clean out a storage room ahead of demo for renovation,, got 4 crank pencil sharpeners NIB, mounted 3 of them in handy places,, we still have 2 originals mounted in our building that was built in the 1960's (don't get rid of what works) :cheers: also as it's a biology dept lots of tweezers (forceps) are around and many have found thier way to me!!! :whoohoo:
« Last Edit: February 12, 2025, 10:44:17 AM by tghs »
what the @#&% over
Offline tghs
« Reply #1475 on: February 12, 2025, 11:11:06 PM »
a little more turning, soldering and much filing and the smaller fitting is ready for a dust off.. base plates turned and threaded.. thru-hull fittings trimmed to lenght.. holes, threading and studs next..
what the @#&% over
« Reply #1476 on: February 12, 2025, 11:17:59 PM »
Great parts. How much more is left to make on this boat?
Offline tghs
« Reply #1477 on: February 12, 2025, 11:52:46 PM »
way to much :facepalm: feed pump needs completion,, boiler needs to be started (most of parts and materials on hand),boiler fittings (site-glass and such) boiler shell and stack (lots of rivets) burner and piping,, I have 2  PM research valve kits, 2 sizes, 4 valves per kit, will have to mod them with flange mountings as per the navy plans,, water tanks and hotwell tank,, prop needs to finished and fitted to shaft which needs to be finished.. canopy frame and canopy.. just a few parts :lolb:
what the @#&% over
« Reply #1478 on: February 13, 2025, 01:16:33 AM »
Pffft... done in a week!   :Jester:
Offline tghs
« Reply #1479 on: February 13, 2025, 01:56:04 PM »
and I forgot the lights that are planned to be a mini brass spinning project,, incorporating evan's flicker LED and battery no wires.. colored tubing to make lenses in a drawer..
what the @#&% over
« Reply #1480 on: February 13, 2025, 02:30:51 PM »
I've got a few full size lanterns like that, will be neat to see the mini versions!
Offline tghs
« Reply #1481 on: February 13, 2025, 10:52:46 PM »
 after drilling,tapping, countersinking and reaming this pair is now ready for installation,,the "holes" in the hull were given an epoxy sealing coat,, will have to make a jig to hold the fittings while the condenser loop get soldered together.. seeing this is low pressure, plumbing solder will be used..
what the @#&% over
  • Oregon
« Reply #1482 on: February 14, 2025, 12:56:06 AM »
Those lamps are gonna be stunning. But they must be sooo small...
« Reply #1483 on: February 14, 2025, 01:02:39 AM »
Looking forward to seeing the metal spinning.
« Reply #1484 on: February 14, 2025, 02:46:20 AM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Just a thought - if the spinning should be a problem in small scale, some miniature press tools used in a drill press or arbor press could be an easy alternate way to do the parts. I can help you with that if you should need to try it. Cheers!
