Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 266039 times)
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1440 on: January 13, 2025, 09:32:55 PM »
Impressive!  Thats a neat pump design, and very well made in miniature!    :praise2:
Offline tghs
« Reply #1441 on: January 13, 2025, 11:15:28 PM »
I give credit for the insperation from many of the metal carvers on this forum :cheers:
what the @#&% over
Offline tghs
« Reply #1442 on: January 23, 2025, 08:38:54 PM »
decided not to cast the smokestack hinge parts,, will do  built up soldered sections,, decided to turn the hardest part first.. the angled ring that fixes the lower hinge to the tapered shell, adjust the compound and let the turnings fly.. Slim back at work inspecting.. :cheers:
what the @#&% over
Online cnr6400
« Reply #1443 on: January 24, 2025, 12:21:00 AM »
Slim looks happy with that!  :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
Offline tghs
« Reply #1444 on: January 26, 2025, 07:48:49 PM »
more work on the stack-hinge-ring..  Slim thinking we are getting ready for the Olympics, the center rings have bevel that fits together upwards to keep the smoke in the stack.. a strip of brass sheet  that went through the 3 in 1 metal machine forms the base that the stack will slide down on. it sits in a groove for soldering,  the bottom bevel ring also has a groove to fit into so all stays in alignment, have to mill and solder the stock for the hinges and the the rings they fit.. the later ring on the restored 40ftr allows for movement in four directions mine will only allow for and aft..
what the @#&% over
Online cnr6400
« Reply #1445 on: January 26, 2025, 08:39:53 PM »
Offline tghs
« Reply #1446 on: January 27, 2025, 06:56:24 PM »
getting a little unhinged today,  made blanks for the hinges and silver soldered the drilled rod in place,, had to cut each section off with a hand jeweler's saw, (i need a slitting saw arbor with a thinner blade retainer..) have mount up a chuck on the mill so the rings can get the fitting recesses cut in them.. :cheers: Slim says I'm overworking his inspection time..
what the @#&% over
« Reply #1447 on: January 27, 2025, 07:06:10 PM »
Nice clean hinges. With all these teensy parts, Slim is going to need a jewellers loupe.   :ThumbsUp:
Offline tghs
« Reply #1448 on: January 27, 2025, 07:33:19 PM »
I'm just getting myself prepped to get back working on the duplex feed pump..
what the @#&% over
Online cnr6400
« Reply #1449 on: January 28, 2025, 03:10:09 AM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Engine and pump look great! Glad to see Slim the grumpy inspector isn't holding a red markup pen or a "Sh^&can It" QC stamp... :Lol:
Offline tghs
« Reply #1450 on: January 29, 2025, 01:57:35 PM »
this assembly is officially half-way there.. could not have done this without the Ti clip/strips :cheers:
what the @#&% over
« Reply #1451 on: January 29, 2025, 03:26:19 PM »
Great looking subassembly, just right thicknesses on the parts!  Those little Ti strips are very handy for holding small parts!
Online cnr6400
« Reply #1452 on: January 29, 2025, 05:01:58 PM »
Offline tghs
« Reply #1453 on: January 30, 2025, 09:59:02 PM »
did two more soldering runs and all the parts are together, :whoohoo: a little reaming (I had planned for that) and 3/32 nds rod will fit through the hinge holes,, still have to make the rods/bolts..  :cheers: Slim get the next couple of days off!!
what the @#&% over
Online cnr6400
« Reply #1454 on: January 31, 2025, 03:24:55 AM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: By the look of it, Slim knows the drill....(bit)  :Lol: Hope he enjoys the time off.
