Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 266039 times)
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1425 on: January 08, 2025, 07:10:50 PM »
Neat.  I wasn't  aware that phosphor bronze wire could make a good spring.  Did you have to stretch it to work harden it?
Offline tghs
« Reply #1426 on: January 08, 2025, 07:44:24 PM »
I cut about a 3ft length, one end in the lathe chuck and a the other end twisted around a wood dowel handle,, hand crank handle in the lathe shaft,, put a good stretch and tension turning the crank.. seems to have worked well,,  :cheers:
what the @#&% over
Offline tghs
« Reply #1427 on: January 09, 2025, 08:50:25 PM »
made the mounting plate with the adjustment slots,, used a sheet of thin clear plastic to mark the hole positions from the pump assembly and transfer them to the mounting plate..the pile of parts in a small space is really adding up!!
what the @#&% over
« Reply #1428 on: January 10, 2025, 12:10:34 AM »
Offline tghs
« Reply #1429 on: January 11, 2025, 04:30:18 PM »
North Carolina snow day!!! :lolb:( I grew up in Wisconsin)  brough home the eccentric strap, hand vise and some files.. a little more cleaned up now  :cheers:
what the @#&% over
Offline tghs
« Reply #1430 on: January 12, 2025, 07:50:45 PM »
the pump pumps  :whoohoo: :cartwheel:, it will draw several inches,, hopefully will post a video in a few hours!!!!! (I'll give Slim the rest of the weekend off!!) :cheers:
what the @#&% over
« Reply #1431 on: January 12, 2025, 08:26:33 PM »
Woo Hoo!    :whoohoo:
Slim is going to be building a squirtgun nozzle for it, better watch out!
Does this pump need to generate pressure to inject into the boiler? Or is this a pump to go back into the water supply tank?
Offline tghs
« Reply #1432 on: January 12, 2025, 08:36:55 PM »
this pump will keep a vacuum  in the keel condenser and return condensed steam to the fresh water tanks,, the duplex navy worthington pump is next on the list after the shop clean-up and organize.. this will be the feed pump for the boiler.. I got a good start on it before pausing to work on making the hull,, :cheers:
what the @#&% over
« Reply #1433 on: January 12, 2025, 08:49:41 PM »
Lots of mach8nery packed into that hull, the worthington pump will be a great project in itself!
Offline tghs
« Reply #1434 on: January 12, 2025, 11:03:51 PM »
not the best vid, but it shows the function!!! :cheers:
<a href="https://www.youtube.com/watch?v=X4M2sb6oFOc" target="_blank">http://www.youtube.com/watch?v=X4M2sb6oFOc</a>
« Last Edit: January 12, 2025, 11:25:36 PM by tghs »
what the @#&% over
« Reply #1435 on: January 13, 2025, 12:08:33 AM »
Very nice!  :ThumbsUp:
« Reply #1436 on: January 13, 2025, 06:39:05 AM »
Great to see it working as it should after all your effort  :ThumbsUp:
Per     :cheers:         :popcorn:
« Reply #1437 on: January 13, 2025, 05:08:36 PM »
Congratulations!  It's always fun to see the thing you made, do the job it was made for!  :cheers:
Offline tghs
« Reply #1438 on: January 13, 2025, 06:16:48 PM »
thanks all,, very happy that the little beasty works, did a vacuum test before it come of the test bed lathe..
<a href="https://www.youtube.com/watch?v=5egQRNrIBv8" target="_blank">http://www.youtube.com/watch?v=5egQRNrIBv8</a>
what the @#&% over
« Reply #1439 on: January 13, 2025, 08:54:56 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: That pulled one heck of a vacuum! Nice!  :cheers:
