Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 140370 times)
Offline tghs
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1380 on: December 14, 2024, 01:27:08 PM »
a little bit of little milling this morning,, opti-visor and trusting the DRO's  :cheers:
what the @#&% over
« Reply #1381 on: December 14, 2024, 02:15:11 PM »
Offline tghs
« Reply #1382 on: December 14, 2024, 06:43:06 PM »
how come little stuff takes so long to make :facepalm: getting closer to soldering day.. left to make, piston, disc valves and springs :cheers:
what the @#&% over
« Reply #1383 on: December 14, 2024, 06:45:33 PM »
Coming along great!  Do you have a drawing of how the valves work?
Offline tghs
« Reply #1384 on: December 14, 2024, 07:32:23 PM »
been working this up with the full scale steam guys,, it's basically a simple double acting pump (Fogg design) hiding in a bailey navy pump body.. the navy pump was complex with small parts even full sized.. 1 pump piston at center showing the water entrance groove/ring.. 2. as the piston moves to the back of the cylinder water and air pushed the spring held disc valve to force things out the exhaust port at the same time creating a vacuum that draws in water when the end of the piston exposes the center groove.. 3. everything starts again in the other direction..(at least that how we hope it will all work!!!)  last pick shows what was involved in replicating the navy pump.. true foundry art!!!
what the @#&% over
« Reply #1385 on: December 14, 2024, 08:19:03 PM »
Thanks for the drawing! Thats a very nice design, most that size are only single acting.   :ThumbsUp: :ThumbsUp:
Offline tghs
« Reply #1386 on: December 15, 2024, 01:08:54 PM »
this is good drawing of the pump designed by Dave Fogg from 1963,, simple in parts as no casting and very little machining is required,, mainly a bored pipe soldered inside a large pipe with some turned rings and flanges.. to keep things simple the eccentric rod was made from modified auto connecting rod!!
what the @#&% over
Offline Charles Lamont
« Reply #1387 on: December 15, 2024, 02:56:37 PM »
This is the air (ie condensate) pump?
Offline tghs
« Reply #1388 on: December 15, 2024, 03:44:14 PM »
yes...eccentric driven to pump out the keel condensor..
what the @#&% over
Offline tghs
« Reply #1389 on: December 16, 2024, 09:21:13 PM »
turned a piston blank and the disc valves,, left the piston a bit large as I'm sure there will be needed clean-up and light reaming of the pump body bore after the soldering.. then the piston can get sized and water grooves added (fine jeweler's saw for the grooves)
what the @#&% over
« Reply #1390 on: December 16, 2024, 10:55:41 PM »
Offline tghs
« Reply #1391 on: December 20, 2024, 01:15:14 PM »
made a soldering attempt, the top section even with the use of Ti. clips would not stay in place,, aborted soldering!!! decided some small locator pins could work,, top has been drilled and pins made,, also ran a section of the wire solder through my rollers and made it flat and thin, will "sandwich" this between the top and base with flux to hopefully get a nice joint,, (no-flow compound will be used to keep solder out of where it doesn't need to be.. also the Temu'd fine chain looks like it will scale well and I have near a lifetime supply
what the @#&% over
« Reply #1392 on: December 20, 2024, 01:28:34 PM »
Looks great!  Slim needs a little navy emblem pendant for his chains.
« Reply #1393 on: December 20, 2024, 01:30:41 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Parts are looking good! Slim looks blinged up. Maybe he's channelling his inner Mr.T?  :Lol:
Offline tghs
« Reply #1394 on: December 20, 2024, 01:34:36 PM »
like a large anchor!!! ;) I had an 8ft hydroplane boat and at the time I was mounting dad's 9.9 evenrude outboard on it, he asked if I had fitted a safety chain. "yep put an eyebolt through the transom for it" dad " put on your ankle it's my motor" :cheers:
what the @#&% over
