Author Topic: 30ft 1890's navy steam launch 1/6th scale  (Read 125142 times)
Re: 30ft 1890's navy steam launch 1/6th scale
« Reply #1305 on: November 07, 2024, 04:29:06 PM »
The supply you have is plenty adequate for  plating model size parts. The one you linked to is a more modern equivalent of the  old lab supply I am using.
« Reply #1306 on: November 09, 2024, 08:17:53 AM »
Splendid  :praise2:  :praise2: I do love your attention to the finest details  :praise2:  :praise2:  :wine1:
Offline tghs
« Reply #1307 on: November 09, 2024, 06:00:01 PM »
made some brass angle stock and soldered on the coal port slides and a section on the rear corner.. the soldering did warp the larger areas but some percussive work from the backside on the smooth surface got them back into flatness.. cut the port holes and made the sliding covers.. I guess these were fairly basic in operation (sailor proof) thinking about having one open with some coal showing.. :cheers:
what the @#&% over
« Reply #1308 on: November 09, 2024, 07:26:51 PM »
Offline tghs
« Reply #1309 on: November 11, 2024, 11:06:00 PM »
found the solution to what to use to hold the plating solution in.. slim may get a shocking experiance if he relaxes to much,, at least pickled.. worked on the watertank boxes, might be down to the last few ash and cherry staves, would be nice to get all this sealed.. :cheers:
what the @#&% over
« Reply #1310 on: November 11, 2024, 11:37:16 PM »
Does that container have a lid? I use one of those plastic food storage boxes with a lid, the plating solution can be reused over and over if kept sealed up, and it saves a day making new solution each time. Whatever you use, dont use it again for food.
 :popcorn: :popcorn:
Offline tghs
« Reply #1311 on: November 11, 2024, 11:47:24 PM »
I have a couple for jars with non-metalic lids for storage,, the pyrex baking dish fits on part at a time without getting into large jars..
what the @#&% over
« Reply #1312 on: November 12, 2024, 02:35:23 AM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Slim seems to be thinking "wonder what the hull speed is in this clear hulled rig?"  :Lol:
Offline tghs
« Reply #1313 on: November 14, 2024, 01:39:15 AM »
my first run at plating,, found my pyrex dish was to small and in my stuff piles located a larger tank.. after getting the electrolite charged plating went well for a first try..
what the @#&% over
« Reply #1314 on: November 14, 2024, 01:51:47 AM »
« Reply #1315 on: November 14, 2024, 01:57:56 AM »
That looks just right!   :ThumbsUp: :ThumbsUp:
Offline tghs
« Reply #1316 on: November 16, 2024, 04:47:00 PM »
with the watertank boxes in place, some measurements showed that my plans and waxes for the condensate were to large,, spent the morning drafting and planning,, came up with drawing that should fit,, also looks like I can use the same build up method that was used on the waxes to mill and carve a pump body from brass.. :cheers:
« Last Edit: November 18, 2024, 01:08:36 PM by tghs »
what the @#&% over
Offline tghs
« Reply #1317 on: November 18, 2024, 01:14:02 PM »
had to come into work early this morning to check on a few things,, did give me the time to get a good start on the condensate pump body,, with use of the soldering clips thinking all the parts (5) can be done in one heat.. I think slim is happy to be back inspecting things around the machines (had to replace most of my DRO's batteries this am) :cheers:
what the @#&% over
« Reply #1318 on: November 18, 2024, 02:31:28 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: I see that Slim's assumed the famous "Deburr Brass Block" yoga position.  :Lol:
Offline tghs
« Reply #1319 on: November 19, 2024, 11:48:02 PM »
A little more brass carving,, think little,, ordered an LED light kit for my opti-visor..
what the @#&% over
