Author Topic: Buffalo steam engine model  (Read 16748 times)
Offline rarach22
Re: Buffalo steam engine model
« Reply #60 on: October 03, 2021, 08:47:47 AM »
thank you, it looks like hot water in the tank where the temperature was high. I have to build it differently ..... I have to build another non-return valve and use a hose to suck in cold water  Pavel :ThumbsUp:
Offline john mills
« Reply #61 on: October 09, 2021, 12:04:40 PM »
Hi
looking at your piping the over flow goes back to the water tank that would sone heat up the water i usually have only a short aver flow pipe
it need to have e free passage to let that initial expansion of steam as it leaves the steam nozzle out it needs to go some were out the over flow this sudden expansion is when the steam condenses slowing down but still at high speed into the combining cone creating a low pressure so the water rushes in and is carried though the combining cone  it needs to be the right volume to be able to continue condense the steam  .as it flows trough the delivery cone it increases pressure to go into the boiler.if the water is to hot it does not condense the steam
and it will stop or not work if it worked to start with it cannot be much wrong.i have made new cones for some 3/8"injectors recently just made what i thought the old cones were badly damaged or missing they all worked and over the full range full boiler pressure down to 20 or 30 psi. when they have stopped working they were blocked with leaves from the feed water .
John.
Offline rarach22
« Reply #62 on: October 28, 2021, 06:00:38 PM »
Thank you very much for your help, the injector works Pavel
<a href="https://www.youtube.com/watch?v=OELW3AKoJbM" target="_blank">http://www.youtube.com/watch?v=OELW3AKoJbM</a>
<a href="https://www.youtube.com/watch?v=MWVDOJEkVsY" target="_blank">http://www.youtube.com/watch?v=MWVDOJEkVsY</a>
Offline MJM460
« Reply #63 on: October 28, 2021, 11:53:42 PM »
Excellent, Pavel, very satisfying.
That little puff of steam and water out of the overflow as it starts is a positive sign that all is well.
Great to see the whole plant working.  Is that a fan being driven by the engine with the ducting to help draft?
Offline john mills
« Reply #64 on: October 29, 2021, 06:10:18 AM »
Parvel
great to see the injector working as it should looks good.
Offline rarach22
« Reply #65 on: November 07, 2021, 08:59:03 PM »
Sorry for czech languagee
<a href="https://www.youtube.com/watch?v=Uhw4rXkc-io" target="_blank">http://www.youtube.com/watch?v=Uhw4rXkc-io</a>
« Reply #66 on: November 07, 2021, 11:30:57 PM »
Beautiful work Pavel, I enjoyed the video.
Offline propforward
  • MN, USA
« Reply #67 on: November 08, 2021, 01:00:40 AM »
Brilliant Pavel!
Forging ahead regardless.
Offline rarach22
« Reply #68 on: March 17, 2022, 09:07:46 PM »
Offline rarach22
« Reply #69 on: March 17, 2022, 09:09:40 PM »
<a href="https://www.youtube.com/watch?v=k1HwsG_jUVc" target="_blank">http://www.youtube.com/watch?v=k1HwsG_jUVc</a>
Dynamo max 7,5V 0,6A
« Reply #70 on: March 18, 2022, 03:06:03 AM »
Pavel...what are you adjusting on the shell of the generator to alter the generator output [voltage]?
It is the positioning of an additional ferric magnet adding to the stator magnetic strength?, so to increase the load demand to overcome the additional stator EMF.........[maybe EMF is an incorrect term?....maybe just strength?]
When asking Google :happyreader: about magnetic strength, it  says.......'one tesla is equal to one weber per square metre:lolb:
:shrug:.... Derek
« Last Edit: March 18, 2022, 03:15:55 AM by derekwarner »
« Reply #71 on: March 18, 2022, 03:51:37 AM »
Great to see the generator in action, never seen that sort of adjustment either, with the magnets.
Excellent work, as always!
Offline rarach22
« Reply #72 on: March 19, 2022, 06:56:51 PM »
<a href="https://www.youtube.com/watch?v=mOl9b8-QVGY" target="_blank">http://www.youtube.com/watch?v=mOl9b8-QVGY</a>
Offline rarach22
« Reply #73 on: March 22, 2022, 10:54:36 AM »
<a href="https://www.youtube.com/watch?v=jUdk9Vg5wYQ" target="_blank">http://www.youtube.com/watch?v=jUdk9Vg5wYQ</a>
Online RReid
« Reply #74 on: March 22, 2022, 02:37:34 PM »
Very impressive! That is a beautifully made and running engine, and with so many fine details. I really like that it provides it's own lighting!  :ThumbsUp:
