Author Topic: Buffalo steam engine model  (Read 16561 times)
Re: Buffalo steam engine model
« Reply #30 on: March 07, 2021, 10:49:49 AM »
Hi Pavel,
a great runner.
Very nice.
Low revs are much more to please.
« Reply #31 on: March 07, 2021, 11:38:49 PM »
Beautiful work and great runner..... :Love:
« Reply #32 on: March 08, 2021, 01:11:50 AM »
Absolutely beautiful work Pavel!
It runs as nice as it looks and I love the concrete base.
Daev
Offline rarach22
« Reply #33 on: March 16, 2021, 07:10:00 AM »
little progress ..... will it work? I will heat the water with steam and a reflection from the boiler .....Pavel
Offline rarach22
« Reply #34 on: March 28, 2021, 08:31:25 PM »
<a href="https://www.youtube.com/watch?v=J8x4n2Yk42I" target="_blank">http://www.youtube.com/watch?v=J8x4n2Yk42I</a>
« Reply #35 on: March 28, 2021, 09:34:10 PM »
Looks good and runs fine Pavel  :ThumbsUp:
« Reply #36 on: March 28, 2021, 09:43:03 PM »
Beautiful work, very well done!
« Reply #37 on: March 29, 2021, 04:52:26 AM »
As always Paval, more than suitably impressed with your valve work. You appear to have in this build selected 90 degree isolation valves for all or both applications
Are these simply 90 degree rotation tapered plug valves?.......apart from using the same saddle cross slide angle setup for both valve bodies and plugs, is there any lapping, or just grease with metal on metal  for sealing?
Without giving any secrets away  :happyreader:  ...do you select say a harder [aluminium bronze] for the valve body then brass for the plug?
Always good to see..... :Doh:
Lastly, what is this?....... a glass cylinder with a free floating Teflon piston with an energised o-ring in an exhaust line?  :facepalm:
regards
Derek
« Last Edit: March 29, 2021, 05:10:46 AM by derekwarner »
Offline rarach22
« Reply #38 on: March 29, 2021, 06:35:54 AM »
regards
Derek
[/quot
Hi, I'll try to answer everything. Sorry for my English. Two glass cylinders - 1 is a thermometer up to 100 C, the other is a float gauge. The steam outlet is connected to a water condensate cooler. I make taps (valves) on a lathe where I set 2.5 degrees. The taps must be applied with abrasive paste.
Pavel
Offline rarach22
« Reply #39 on: April 30, 2021, 07:11:37 PM »
« Reply #40 on: April 30, 2021, 07:39:52 PM »
Wow...just...wow.  Gorgeous work Pavel!
« Reply #41 on: April 30, 2021, 07:46:14 PM »
Terrific workmanship!
« Reply #42 on: May 06, 2021, 05:25:54 PM »
Hi Pavel, very nice. As Always.
Offline rarach22
« Reply #43 on: May 08, 2021, 12:03:23 PM »
Offline rarach22
« Reply #44 on: June 07, 2021, 12:12:09 AM »
