Author Topic: Junkers CLM  (Read 104748 times)
Re: Junkers CLM
« Reply #315 on: January 27, 2025, 06:01:02 PM »
Roger, I'm very pleased that all the work was worth it.
Re: Junkers CLM
« Reply #316 on: February 09, 2025, 10:02:26 AM »
Thank you both  :)
Next up is mass production of the air valves for the scavenge pump, 12 in all. The turning of the main valves, the spring caps and the spring guides were all carried out using parting tools so as not to have to keep changing them. The M3 stainless studding was cut with a junior hacksaw and finished with a file in the lathe. I have made 13 of everything assuming that at some point a part will be taken by the swarf gnomes.
Re: Junkers CLM
« Reply #317 on: February 09, 2025, 02:01:02 PM »
Re: Junkers CLM
« Reply #318 on: February 09, 2025, 04:14:54 PM »
That's a real production run, Roger!   :ThumbsUp: :popcorn:
Re: Junkers CLM
« Reply #319 on: February 09, 2025, 05:44:40 PM »
It looks like a successful series production 👍.
Re: Junkers CLM
« Reply #320 on: February 16, 2025, 05:28:38 PM »
Thank you all  :ThumbsUp:
The series production continues. I finished of the spring guides and the moved on to milling the air valve bodies. The first stage was cut in 0.5 mm steps with a 3mm end mill at 10 000 rpm. The sectors were then cut with a 2mm end mill in 3 75° steps. Luckily my small RT just turns freely, winding a handle would have been tedious. Next step lots of deburring and polishing the sealing faces  ::)
I am now looking at the rest of the scavenge pump, checking the piston clearance and marking out for the holes for the air valves.
Re: Junkers CLM
« Reply #321 on: February 16, 2025, 05:34:54 PM »
Re: Junkers CLM
« Reply #322 on: February 23, 2025, 02:43:45 PM »
The hole for the air valves were drilled out 8mm and then 12mm. The 14mm recess was cut with an end mill, centring each time with a 12mm bar. Their is a slight overlap between the valves which can be solved with a little filing.
Next I milled a recess in the top of the cylinder block to allow the air to flow from the valves to the inlet ports. There are still the connecting holes to drill.
Re: Junkers CLM
« Reply #323 on: February 23, 2025, 02:50:11 PM »
Unfortunately I didn't allow for the 3mm thick pullrod cover plates so the first recess was too narrow. Back in the mill again.
A little bit of filing got all the valves in place so I polished the sealing faces on some fine abrasive cloth and started assembling them. The studs were Loctited into the body with a high strength grade then the rest was assembled using a medium grade in case I have to dismantle them in the future.
The next stage is to make a new, better fitting scavenge piston.
  • Oregon
Re: Junkers CLM
« Reply #324 on: February 23, 2025, 03:24:00 PM »
Lots of detailed and finicky work embodied in those recent sequences. Nicely done and great progress! :ThumbsUp: :ThumbsUp: :wine1:
Re: Junkers CLM
« Reply #325 on: February 23, 2025, 05:14:01 PM »
Wow!  I'll say!   Amazing work, Roger!  :ThumbsUp: :popcorn:
Re: Junkers CLM
« Reply #326 on: February 23, 2025, 08:53:29 PM »
Re: Junkers CLM
« Reply #327 on: March 03, 2025, 07:09:17 AM »
Thank you  :)
On with the new scavenge piston. It was machined to a close fit on the long axis but this is difficult to check as it tends to tilt and jam. The corners were then rounded and with a bit of hand fettling it fits. It is easiest to check using an adaptor in the bench drill as it keeps it square. The new piston is 0.05 - 0.08mm larger than the first attempt so hopefully it will seal well enough. Thermal expansion may be a problem but it is at the 'cold (inlet)' end of the engine so hopefully ok.
Next up were the air passages from the scavenge pump to the inlet ports. I hope they are not too restricting, if so I will mill them out to a slot. Finally a couple of counterbores in the piston to recess the fixing nuts.
Re: Junkers CLM
« Reply #328 on: March 03, 2025, 04:46:32 PM »
Nice progress - fingers crossed and hope that you end up with a working Engine  :ThumbsUp:   :ThumbsUp:
Per       :cheers:          :popcorn:
Re: Junkers CLM
« Reply #329 on: March 03, 2025, 07:39:17 PM »
