Author Topic: Junkers CLM  (Read 41736 times)
Re: Junkers CLM
« Reply #135 on: April 13, 2024, 08:06:13 AM »
On with the pull rods. The second one was turned to 8mm for most of the length and then reduced to 6mm at the end. I then modified a grooving tool I had previously made to give an (approximate) 0.5mm radius. This was then used to cut a stress relief groove for the end of the thread and to radius the transition between the 6 mm and 8mm sections. The end was then threaded M6 x 0.5mm.
Next I need to machine the little ends to fit a 15mm diameter ball race. I have a 15mm plug gauge so I will try to get the fit correct. There is always Loctite as a back up  ::)
Re: Junkers CLM
« Reply #136 on: April 13, 2024, 08:10:28 AM »
To mark out for radiusing the little end I needed a centring plug. This was quickly made on the Proxxon lathe from an offcut of 6mm silver steel (drill rod).
Finally I needed to look at how to cut the three slices for the big ends. They could be sawn on the band saw and then milled true but it looks like I can just about use a slitting saw in the lathe which will be easier in the long run.
Re: Junkers CLM
« Reply #137 on: April 13, 2024, 12:25:53 PM »
I get why you need to make the Long-Rods in two pieces - but how do you ensure thay are the same lenght afterwards  :thinking:
Having threads in the pieces themselves introduce another problem in my mind (I really hope I'm wrong here) - where you now have both length and angles interlocked (360 more potential problems) ....
Best wishes
Per      :cheers:
Re: Junkers CLM
« Reply #138 on: April 14, 2024, 08:07:04 AM »
Hello Per, I have a solution planned. The thread is 0.5mm pitch so half a turn is 0.25mm. I will able to skim this much off the pad on the end of whichever rod is longer. I could also just shim it as the big ends are designed in three pieces so I can adjust the compression ratio. The little end and the pad we be aligned parallel on the surface plate and then be left there for the Loctite to cure. (The drawing is in picture 296)
The next step was to centre the rotary table and set up to radius the little ends. I knew that the clearances would be tight. The pair came out quite nicely  :) I will leave the 'ears' on for the moment to help with clamping to bore for the little end ball races.
Re: Junkers CLM
« Reply #139 on: April 14, 2024, 04:52:00 PM »
The rods are coming along nicely, Roger!  :ThumbsUp: :popcorn: :popcorn:
Re: Junkers CLM
« Reply #140 on: April 20, 2024, 08:02:58 AM »
Thank you Kim, it's a slow process  ::)
The rods were supported using a couple of 6mm HSS tool blanks as parallels and then were centred under the mill chuck. The bore was opened out to 10mm and then 13mm. Taking small steps the bore was opened out until the go end of the plug gauge (14.98mm) just entered. The bearing wouldn't go in under finger pressure so I am hopefully in the right area for an interference fit. Next I cut the 'ears' off with a hacksaw and finished profiling the end with a 3mm radius tool.
Re: Junkers CLM
« Reply #141 on: April 20, 2024, 08:06:25 AM »
The second rod was finished in the same way and I started cleaning then up. There are some machining marks on the shaft where the two turning operations met that I will have to polish out although there is not much bending stress at that end of the rod mostly tension when the engine is running.
Re: Junkers CLM
« Reply #142 on: April 20, 2024, 09:45:22 AM »
Glad that you have planed for it all and the result looks good  :ThumbsUp:
Per           :cheers:
Re: Junkers CLM
« Reply #143 on: April 20, 2024, 12:56:14 PM »
Hello Roger,
Very long and slender 'Pull' rods. Nice transition from shaft to the bearing eye.  :ThumbsUp: :ThumbsUp:
It looks like you had to hold the square shaft in a round collet? Any problems with the corners interfering with the collet's slits?
Re: Junkers CLM
« Reply #144 on: April 20, 2024, 08:14:55 PM »
Very nice work, Roger. I've also used ER collets to hold square stock for turning, seems to work quite well. :ThumbsUp: :ThumbsUp:
Re: Junkers CLM
« Reply #145 on: April 20, 2024, 08:54:10 PM »
Thanks that's always good to know
Re: Junkers CLM
« Reply #146 on: April 21, 2024, 07:46:15 AM »
Thank you both  :)  The sides of the rods are round so there was no problem clamping in the ER collet but I have also successfully clamped square stock, you do have to take care with the alignment of the corners and the slits.
Next up is the big ends. The first step is to cut a piece of 30 x 10mm aluminium down to 24mm. I could have used a hacksaw and the mill but decided to use a slitting saw. This seemed to work well and gave a nice finish but it was not flat or square  :( With hindsight the 0.8mm slitting saw was to thin  :facepalm2: Not a big problem as the deviation was in the plus direction so it could be finished in the mill.
I now need to reconsider the slitting saw that I will use to cut the slices for the big ends  :headscratch:
Re: Junkers CLM
« Reply #147 on: April 28, 2024, 12:22:35 PM »
Whilst the blank was in the mill I squared off the end. Next it was set on the angle plate to drill and ream 3mm for the big end studs. The depth was planned such that the ends of the holes wold disappear in the last saw cut. After the previous experience I decided to use a 1.5mm thick slitting saw. This seemed to stay true and square  ::)
Re: Junkers CLM
« Reply #148 on: April 28, 2024, 12:33:15 PM »
I had marked the rod position with a spotting drill which I then opened out with a centre drill for the next operations. The rod end block was centred in the 4 jaw chuck using a couple of 12mm wavy parallels to give clearance for the profiling later.
The rod fixing was drilled 5.5mm , counterbored with a 6mm end mill and tapped M5 x 0.5. Next the rod was screwed in to help support the block during profiling. Both rods had very little run out  :). Getting the 4mm profiling tool in the right place was a bit fiddley but profiling the block went without problems using a 0.3mm depth of cut.
Re: Junkers CLM
« Reply #149 on: April 28, 2024, 12:40:35 PM »
Could this be classed as 'Tuning' the engine?
<a href="https://www.youtube.com/watch?v=nvO9_MaiuGc" target="_blank">http://www.youtube.com/watch?v=nvO9_MaiuGc</a>
The finished rods were then mounted on the go end of the plug gauge to compare the lengths. Looks pretty good  :)  I now have to decide when to Loctite the two parts together. It will be a tricky job as I only have a few seconds the screw the parts together and align them before the Loctite starts to bite.
« Last Edit: April 28, 2024, 12:45:40 PM by Roger B »
