Author Topic: Coax Indicator, designed by W.K.Todd  (Read 18830 times)
Re: Coax Indicator, designed by W.K.Todd
« Reply #45 on: May 09, 2024, 06:42:16 PM »
Hello Bill,
Thanks for posting the new link.   :ThumbsUp: :ThumbsUp:
I see you have updated the PDF by adding a ghost cross section view
« Reply #46 on: May 09, 2024, 07:13:45 PM »
Thanks for the link Bill!  I had seen this thread way back, and wound up buying an off the shelf one. It works, but its about 2" taller than your design, which is often a problem. Your version would save a lot of vertical height on my small mill. Going on my build list! I should be able to re-use the probe arms at least  from the one I bought, maybe more.
 :cheers: :cheers:
« Reply #47 on: May 15, 2024, 11:33:11 PM »
Wow, thanks Bill!  Downloaded a copy of the drawings for home use.  :ThumbsUp:
