Author Topic: Easton and Andersom beam engine at Bressingham.  (Read 74349 times)
Re: Easton and Andersom beam engine at Bressingham.
« Reply #630 on: January 17, 2021, 02:34:10 AM »
Hi Willy,
Its one L in Stilwell, and Dayton Ohio, not Daytona. This link has a bunch of info, including the name they changed to.  Dayton is currently the home of a giant US Air Force plane museum, well worth the visit to any in the area. Bit far for you Willy!
http://www.vintagemachinery.org/mfgindex/detail.aspx?id=11337
« Reply #631 on: January 17, 2021, 05:36:02 PM »
Hi Chris, thanks so much for this ..really interesting info..Something to get my teeth Into...I wonder if they have a large Archive ??
Willy
And a couple of pics of the victor turbine here in Blighty and the image in the text that you kindly sent to me !!!with the small brass gear part !!!
« Last Edit: January 17, 2021, 05:57:03 PM by steam guy willy »
« Reply #632 on: January 17, 2021, 08:01:08 PM »
That site has a lot of good info on a lot of manufacturers. Also, if you click on the Publications and Images tabs on the Stilwell page, they have some catalogs scanned that you can view.
« Reply #633 on: January 21, 2021, 02:03:52 AM »
Thanks Chris, yes there is a lot of info on the web ..I spent a lot of time on Graces Guide but now you have to pay for it ?!!
More work on the oil pots after havingnbeen glued to the telly over the past couple of weeks ???  There is a lid on the grease pot and this has a nurled feature that is made by pushing a needle file over it  with the belt drive disconnected ..it is a cross cut file so seams to work well...I have also used the 10 BA die to hold the parts while I clean them up after parting off...
Willy
« Last Edit: January 22, 2021, 04:44:27 AM by steam guy willy »
« Reply #634 on: January 23, 2021, 03:36:16 AM »
Ok ...so the oil and grease pots are made and the straps have been tidied up ..so the con rod needs to be finished and then ready to photograph and display  and a name plate attached ....
Willy
« Last Edit: January 23, 2021, 04:04:16 AM by steam guy willy »
« Reply #635 on: January 23, 2021, 03:42:00 AM »
Purty!
Offline MJM460
« Reply #636 on: January 23, 2021, 10:11:01 AM »
Beautiful work Willy.  Those oilers really finish it off.
« Reply #637 on: January 27, 2021, 03:27:55 AM »
So ..making the adjustable jib and cotter. for the lower con rod bearing ...a 12 BA bolt is silver soldered to the jib and a also the cotter has a small part attached ..so fitting up prior  to cleaning up...still find more small parts to make !!
willy
simplyloco
« Reply #638 on: January 27, 2021, 09:22:11 AM »
Very neat indeed!
Offline scc
  • Lancashire, UK
« Reply #639 on: January 27, 2021, 06:34:08 PM »
Willy,  you have very skillfull, nimble "watchmakers" fingers.  Impressive work :praise2:        Terry
Offline gary.a.ayres
« Reply #640 on: January 28, 2021, 10:50:17 PM »
Looking great...
« Reply #641 on: January 29, 2021, 02:40:33 AM »
Hi All ,thanks for the comments  ..and the con rod top jib and cotter is finished ..
still lots of small components tor sort out  and I need to get some proper lights to illuminate  it ?!!
Willy
« Reply #642 on: February 12, 2021, 03:01:53 AM »
back in the WKSP. and the last part is the very small oilers for the crankshaft... I have made an indexing device for the hexagon nut and the 4 other oil viewing holes.. I have used the bull wheel on the Myford to mark out the indexing hole positions and have painted them to quickly reference the correct spacing for filing and drilling the oiler....
Willy
« Reply #643 on: February 12, 2021, 05:23:43 AM »
Still following you Willy and love the detail work you do....... :Love:
« Reply #644 on: February 13, 2021, 03:04:21 AM »
Thanks Don , and we all do Wonderfull work on here !!  So the hexagons are now filed using the hardened steel jig..the indexing worked a treat
Next job is the 4 holes
Willy
