OK, Folks, This part went ok, but there was a bit of tweaking the geometry to get the miter gears to fit nice. The vertical shaft will later hold the governor. Having the timing gears, shafts, and cranks in place, I can work on getting the Lee Shaft built and in place. I will be using steel rods with 3D printed rod ends. The rods are way too thin to get a good print, and even if I was able, the plastic would be just too weak. This is getting into the more tricky part of the engine where some really small parts have to fit and work. We'll see how it goes.
maury
