You may have reached the point where it makes sense to try to apply full test pressure. The remaining leaks appear to be quite small and would not be expected to cause any structural issues.The boiler will definitely "move" when pressurized. Some moves may be positive and others not so positive. But in either case the boiler will be much closer to its working configuration.In use, those tiny leaks tend to heal up by themselves as they get jammed with crud. Of course it is nice to start with a perfect leak-free boiler. Gene
I hope that all those other tools and things in the background are farther away than they look in the picture so they dont get melted!
Once while working on silver soldering out in the driveway in the summer a neighbor came strolling up to see what I was doing, right into the flames path! Had to wave them off to the side, where their eyes got real big when they saw the flame from the torch! With the bright sun where they were and me in the shade they hadn't seen it, just heard the roar from the torch.
(You're up early! )
I got the Sawzall (Dewalt) with the variable speed so I'm ready to cut the other seven tender wheels!
And...I'm up to Page 182 on your writing. Interesting - and I'll be sure to print it out to follow. -Jim
