Here they are, painted and re-assembled
That feature on the front face is probably a device to slow down any oil drips to retain them to the assembly as long as possible... that would be my story! If you can't easily fix it - feature it!
It just has that extra beauty mark on the side face now…
QuoteIt just has that extra beauty mark on the side face now… ... and me who thought that it was a recessed Quality Stamp .... Per
Hello Kim, at first I thought the hole was set completely wrong. But the hole is only drilled.It wouldn't have been bad and you would have tapped both holes.And the hole that is not needed is closed with a cap. So a combined eccentric for both installation options. Vertical or Horizontal.But again a beautiful part that is finished.Michael
Oil cup for that eccentric could be hard to access being between the frames.
