Looking good Is the slight pink tinge on the cylinders due to the pickling?
Interestingly, the whole thing is VERY front-heavy right now.
Kim....... not being familiar with this engine, design or build, what type of gasket material will you be using on these two principal joint faces between the T distribution body and the cylinder block faces?Derek
QuoteInterestingly, the whole thing is VERY front-heavy right now.I had the same issue with the little 0-4-0 I built. I kept a weight attached to the rear of the frame until the boiler went on, then it wasn't needed anymore.
