question for you kimhttp://www.modelenginemaker.com/index.php/topic,8552.msg211772.html#msg211772on this part, the fixturing of the tender top plate. what was your method to drill the angled holes.. did you plunge straigth or perpendicular to the surface. if so.. what kind of setup did you use. neither you or quinn showed the money shot on that part. i'm looking for wisdom as it is quite a lot of work and quite stressfull with all the trouble getting to that point.ThanksPogo
I was thinking going from the center toward the ends to prevent some wavyness. Is that a good plan?
It's an X if you work (or worked) at Xerox or that tweeting company. Local to me it would be called a cross or a 4 way cross. Stay cool in the heat wave Kim.
