Way back when I was into DIY audio, I built a pre-amp from a kit (still have it). Much of the wire I used was silver coated copper hook-up wire with a PTFE insulation. One of the advantages of this wire was the insulation is really tough and can withstand high temperatures which may be helpful for you. You didn't need to worry about the insulation melting back when soldering, although you could probably damage it with prolonged high heat. This wire is stiff and retains it's shape which also nice.
Quote from: Krypto on May 21, 2024, 03:16:00 AMWay back when I was into DIY audio, I built a pre-amp from a kit (still have it). Much of the wire I used was silver coated copper hook-up wire with a PTFE insulation. One of the advantages of this wire was the insulation is really tough and can withstand high temperatures which may be helpful for you. You didn't need to worry about the insulation melting back when soldering, although you could probably damage it with prolonged high heat. This wire is stiff and retains it's shape which also nice. I've got a bunch of wire that sounds very similar to that - it came from Cammell Lairds in the 1980s, and was apparently used on submarines. It's an absolute bear to use... I got 2 or 3 reels in maybe 1987-88 or thereabouts, and I must have used about 6 feet of it....
Sounds like a lifetime supply, Ade!
It won't interfere with the sand dome pipes will it?
