The stack was started from a ~4” length of 1.25” diameter 303 Stainless rod. I faced it off to the required length, then proceeded to drill it through. However, all my good drill bits are machine screw length, so were not long enough to go more than about halfway through the bar. So, I drilled a blind hold halfway through, starting at 1/4":
Then step drilled in 1/16” increments up to 1/2".
At which point, I turned the bar around and did the same process again. By doing this, the holes from each end met in the middle. I was worried about the holes from each end not being aligned but figured it would be close enough for a smoke stack. Seems to have worked out pretty well. I can’t feel an edge between the two holes, so I’m happy.
Now, I wanted to go up to 5/8”. And my cheap HF Silver & Deming bits are long enough to go all the way through. So I stepped up to 9/16” then 5/8” which went well.
Next, I brought the outside end of the stack down to 7/8”. This will be the part that sits in the base.
Like so – only, the base is upside down in this picture… Oops…
Then I bored a length in the end up to 11/16”.
And added a 60
o chamfer to the inside bottom of the smokestack.
I flipped the stack around holding the 7/8” diameter in a 5C collet. Next, we’ll be tapering the inside of the stack. To do this, I carefully adjusted the compound to 1.95
o. To get the required accuracy, I used the X-offset over Z-distance method to set the angle precisely. 1.95
o sounds rather arbitrary, but it’s really just what is required to connect the two inside dimensions with a single taper.
Then I proceeded to actually bore the taper. This took a lot of long cranking sessions moving the compound slide back and forth. No power feed on the compound!
I then added a small 60
o chamfer on the top of the stack (sorry, no pic) and used a live center to help hold the part steady while tapering the outside. I started by defining the top radius of the stack, just below what will be the decorative ring. I did this with the grooving tool.
Then I used my favorite tangential tool to take off the bulk of the material before actually starting the tapering.
And after carefully setting the compound taper to its new required value of 1.05
o, I tapered the outside of the stack. I had to switch to the lefthanded tool to get the last bit of taper up to the top of the stack. Now, all of the outside dimensions up to this point are about 1/64” over their final size. After soldering we’ll take down that last bit to clean things up and blend the two parts together.
And here we are AFTER silver soldering the two parts together. Annoyingly, I forgot to take a picture of the stack piece before soldering. But hopefully, you can imagine what it might have looked like.
The part is now being pickled. Tomorrow we’ll move forward with the final shaping of the smoke stack!
