Hi KimThe ash pan turned out great!Yes, sheet metal will always stretch through the bend, this is something that people who work with sheet metal deal with every day. On a press brake with known material and tooling it is somewhat easier to predict, but there is always variables that will change things.The easiest thing you can do is take a strip of the sheet that you are planning to use, say 1"X 4". Measure the length and then bend it 90 degrees, approximately in the center across the short direction. Use the same method that you will use on your actual part. Measure the outside length of each leg and add them together. Then subtract the original length value from the sum of the two folded legs. This will give you your outside bend deduction. this amount needs to be subtracted from your flat pattern for each bend. Bends less than 90 will take some trial and error to get the proper bend deduction. We have sheet metal software at work that does a pretty good job of this, once you have a good value for the 90 degree bend.Hopefully this helps some.Dave
That's a beautiful latch / unlatch action Kim! Careful you don't get LDEGv* though. *LDEGv= latch detent euphoria, Goldilocks variant , commonly caused by machine builders operating mechanisms that are just right ..... (very common when building Kozo's designs)
Outstanding work Kim! Your soldering skills are excellent you should have no problem with the boiler fab and soldering……….I ……….likeeeeeee…. Don
