Here’s the tie plate after some clean-up. You can see that the feet stand a little proud (1/64”) of the bottom of the tie plate. That will come off here soon.
But first, I drilled the 3-48 mounting holes to mound the tie plate to the chassis.
After this, I shaved down the feet and took a very light skim off of the bottom just to make sure things were completely even. I also took this opportunity to shave the feet down to size (I’d left the length a little oversize before).
Next we have to cut a very small relief angle in the bottom of the plate in two places. Kozo specifies 55
o, though I doubt the angle is really that critical.
Because it’s just to make sure the tie plate clears the rims of the drivers. It’s important to clear the drivers for sure! But I’m not convinced that the 55
o angle is super important to that!
Here’s a shot to show you what that little clearance cut was for (see the little tiny notches right over the rim of the front drivers? - that's what I just cut.)
Now I need to drill the holes to connect the yoke guides (3 on each side):
And tape them 3-48.
The final op for this piece is to take the curve out so that it nests with the boiler well. I know you could just hacksaw and file this out, but I want to do it on the rotary table. To do this, I drilled a couple of holes in the piece that will be removed. These are tight clearance for 10-32 screws.
And finally, I drilled some matching 10-32 tapped holes in a piece of aluminum that I use for a rotary table jig. It already has some nicely placed 1/4" holes in it. So I used one of those holes, and measured out with the DRO, and placed my holes. Unfortunately, I did my calculations wrong. This should make a 1.875” radius arc, instead, I’m getting a 1 3/4” arc. But after being frustrated with myself for a bit, I’ve now figured out that I can use this anyway. All I need to do is shift the jig over 1/8” on the RT before I start. And I should be golden. The locator hole doesn’t really have to be at the center – that was my original intent, but my poor math prevented that from coming true. But it shouldn’t matter.
Anyway, we’ll see if my jig-save works tomorrow. I’m done for today.
Thanks for taking a look!
