Chapter 14.7 – Cylinder Head CoversToday I tackled the Cylinder Head Covers. These are somewhat decorative covers that go over each end of the cylinder. I assume the purpose is the same as the Steam Chest Cover Casings – probably heat insulation? But for me, they are mostly to make it look cool!
The cylinder head covers are made from the same 1.5” brass rod I’ve been using for the last few parts. However, this time, I leave it at 1.5” diameter and hollow out one end so it will fit over the cylinder heads.
I stared with the rear end-covers. So the first step was to bore out a hole to 0.830”, just big enough to slip over the o-ring holders in the rear cylinder covers.
Here’s the test fit:
Then I bored out to 1.441” (an easy sliding fit for the 1 7/16” cylinder size) to a depth of 15/64”.
And lastly, cut it from the parent stock.
I repeated this again for the other cylinder then did two more for the front end. Those were even easier since they didn’t require the initial 0.830” bore, just a #3-48 clearance hole.
Next, I flipped one of the covers around in my small Taig 3” 4-jaw chuck. After centering it up, I faced off the top side where it was parted:
Then used the 3/32” round-over bit to put a nice corner on the cover. You'll notice I was using the live center to provide more assurance that the part would stay in place while using that round-over bit as a form tool. Unfortunately, I couldn't do that for the rear covers since they had a big hole in the center. But I took it slow and careful, using very light cuts, and everything held.
And here are all four of the covers completed. The top two are the Front Cylinder Head Covers, and the lower two are the Rear Cylinder Head Covers.
And as I like to do, I’ll finish this post with the cylinder family shot, having added the front and rear covers to the cylinder assemblies. In this picture, I have one facing forward and one facing back so you can see how the covers look on both ends.
And by this time I was melting into a puddle on the shop floor so it was time for me to ooze back into the air-conditioned house.
Thanks for taking a look!
