Author Topic: Morton M5  (Read 7472 times)
Re: Morton M5
« Reply #45 on: June 28, 2021, 09:17:31 PM »
Just beautiful and a very nice description on how you did it - I'm enjoying to see this again - so thank you George  :cheers:
Re: Morton M5
« Reply #46 on: July 02, 2021, 12:03:51 AM »
The heads probably took the most time for an individual part, not counting there was 5 of them. I started with round stock and turned the combustion chamber counterbore and the fins. I drilled a hole to the depth of the combustion chamber then made a conical tool from drill rod to cut the shape.
Re: Morton M5
« Reply #47 on: July 02, 2021, 12:10:07 AM »
The head was laid out with center lines then set up in the mill to put the valve pockets in. I calculated the distance needed in CAD, picked up the center lines then drilled and reamed for the valve guides and pockets.
Re: Morton M5
« Reply #48 on: July 02, 2021, 12:16:56 AM »
The head was securely screwed onto a threaded mandrel then put into the mill vise. The head was tilted to the required angle and initial milling started for the various shapes and fins. I blued up the boss shape around the valve guide hole and stepped the radius off.
Re: Morton M5
« Reply #49 on: July 02, 2021, 12:20:34 AM »
The next step was to put the top fins onto the head. This was accomplished with a slittng saw of the proper thickness.
Re: Morton M5
« Reply #50 on: July 02, 2021, 12:24:14 AM »
Some final pictures of the head with all the holes drilled and tapped. The heads will have steel valve seats pressed in and bronze guides also pressed in place.
