Author Topic: Bruce Macbeth Engine, European Version  (Read 79028 times)
« Reply #630 on: January 19, 2022, 12:18:19 PM »
That was a very interesting little tidbit Roger - do you have any reference, or was it just told verbaly to you ?
Nice CAD work Achim - I hope it will solve your last problem  :ThumbsUp:
Offline Rustkolector
« Reply #631 on: January 19, 2022, 03:34:40 PM »
Achim,
Have you verified the closing degrees of all your valves. The closing degrees are very important.
Jeff
« Reply #632 on: January 19, 2022, 03:59:08 PM »
Achim,
Jeff
Hi Jeff, to be honest, no.
Not so far.
I have only done the adjustment with focus at the opening of every single valve.
At the next opportunity I can do this.
Do you have any values/figures as reference ?
Today was the day of assembling the entire components again.
« Reply #633 on: January 19, 2022, 04:17:49 PM »
Wow that looks nice!!
« Reply #634 on: January 19, 2022, 05:29:09 PM »
Wow is right! That's Beautiful, Achim!
PS The little red fire extinguisher detail really caught my eye.  Love those tiny details!
« Reply #635 on: January 20, 2022, 01:26:29 AM »
That really does look wonderful. The "base as mini-diorama" really sets the engine off well, and also puts it into context.  :ThumbsUp:
« Reply #636 on: January 20, 2022, 04:59:13 AM »
Achim,
You need to verify valve opening and closing degrees to determine the correct valve duration. When things don't work as expected, it is a logical place to start looking for the problem. Nominal durations: I - 200, E - 220 with no overlap at TDC.
Jeff
« Reply #637 on: January 20, 2022, 09:54:37 AM »
Great to see you have your model running.  It looks fantastic.
« Reply #638 on: January 20, 2022, 11:45:36 AM »
Truly outstanding work!  The whole presentation is wonderful!
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #639 on: January 20, 2022, 01:30:28 PM »
Pardon my late reply.....
I'm glad to see the final version of this engine completed.
I have to say that I think you are a confirmed detail worker who wants to make it exactly the way you plan it and I admire the way you went about it and I enjoyed every post you made.
If you start something new, I will be following.
ShopShoe
« Reply #640 on: January 20, 2022, 08:37:48 PM »
I found this by a number of routes. L C Mason refers to a carb with two butterflies, one before the jet and one after and the relationship between them. I have a couple of commercial carbs that I have modified for my engines and noted that the air intake bore was bigger that the bore in the barrel and the engine side bore. If you go to the extreme and make the inlet side bore bigger than the air intake side you will end up drawing neat fuel and no air. For a high volume production finding the optimal bore can be done by experiment. For a one off as soon as you open the air intake past the optimum you have to make a new body  ::)
« Reply #641 on: January 20, 2022, 08:56:36 PM »
Achim,
I do enjoy the attention to the small details that you and many others on here put into your work  :praise2:  :praise2:
« Reply #642 on: January 20, 2022, 11:15:09 PM »
Well that goes without saying  ;D  - not that it will prevent me from making that mistake  :-X
Like the rest here - I really enjoy to see your last pictures Achim - amazingly result  :praise2:
« Reply #643 on: January 21, 2022, 04:59:21 AM »
Outstanding work Achim enjoyed your build  …… :Love:
 :drinking-41:
« Reply #644 on: January 21, 2022, 06:40:50 AM »
Don, Per, Roger, ShopShoe, George, Craig, Jeff, Ron, Kim and Dave thanks for watching and all the friendly comments.
Very good to know that you are all following, I do appreciate it very much.
I am very happy to be a member of this friendly and global community.
« Last Edit: January 21, 2022, 07:39:57 AM by fumopuc »
