Yes, you're certainly close! I don't have IC experience so can't give you any input there, but it looks great and sounds really good while it's going. I know you'll get there!Kim
Sounds very promising - so you can't be far of a sustained run I can't make out if you are trying to open the Throttle fully with your finger in the video and if that is where you are closest to it running by itself ....Next thought : if you require an adapter to fit the bigger Carburetor - will you get a bigger area in the smallest diameter all the way to either where the Manifold divides or will it not be the Venturi that is the smallest ?It should make a difference, if it's still the Venturi with the bigger Carburetor.The model looks great
Almost there Have you rechecked the valve and ignition timing in case something has moved/slipped?
