Author Topic: Bruce Macbeth Engine, European Version  (Read 78657 times)
Re: Bruce Macbeth Engine, European Version
« Reply #405 on: March 07, 2021, 03:28:10 PM »
Hi everybody, here the last progress for the exhaust.
Soft soldering of tube and flange.
Some gaskets and everything in situ.
Now the coolant has to get out of the engine.
First part of the coolant return pipe made and pressure tested.
« Reply #406 on: March 07, 2021, 11:35:58 PM »
Very nice progress Achim. On the solder your right to assume that the flux did in fact push the solder.  I have had that happen to me. I think if you would of tinned the part first before piecing it together you would of had solder there ready to flow with flux and heat then add as needed in some parts. With proper jig it could be done to insure the parts go together properly. Like Per said keep the heat moving and don’t let the part get too hot or the heavy area needing solder will flow out of the gaps. It hard to concentrate on both heatiing and adding soldering to the right amount sometimes with larger parts. Just my two cents.... You work is outstanding.
Regards
« Reply #407 on: March 08, 2021, 06:19:04 AM »
Hi Don, thanks.
You have remind me now, that there must be a little can with silver solder paste anywhere.
For the next time I will try to use this, may be only to get it tinned.
On the other side, with enough of this paste it may will work in this application also finally.
Another attempt, to get it work with less flux would sure also solve the problem.
Unfortunately here it was my last solder of an old  batch, still containing some Cadmium (the old stuff, not anymore allowed in Germany ) and I didn´t want to mix it with another new style silver solder.
« Last Edit: March 08, 2021, 01:02:31 PM by fumopuc »
« Reply #408 on: March 08, 2021, 06:33:56 AM »
Hi everybody, more coolant return.
Soft soldering in situ was successful.
The plotter has cut some gaskets.
The M 1,6 bolts will be replaced later against a hex type.
Another connection point is scheduled in the pipe to avoid a later split between the manifold and the two pipe flanges, because this will a nightmare to solve 8 times a M 1,6 mm hex bolt there.
Next part to make, that all is laying on the table for closing the loop, the long pipe from the head down to reservoir.
Offline scc
  • Lancashire, UK
« Reply #409 on: March 08, 2021, 11:15:23 AM »
Gorgeous engine Achim. :cheers:        Terry
« Reply #410 on: March 08, 2021, 01:46:01 PM »
Very nice work Achim, I’ve stated it before but the statement bears repeating; you’re building a beautiful model.
Soldering I something my eyes just won’t let me attempt any longer, can’t seem to see what I’m doing well enough without burning my eyebrows off :ROFL:.  The little soldering I need to do is usually substituted with Locktite.  :ThumbsUp:
« Reply #411 on: March 09, 2021, 11:21:06 AM »
Thank you Terry, go to know you are still following this long time project.
« Reply #412 on: March 09, 2021, 11:23:37 AM »
Soldering I something my eyes just won’t let me attempt any longer, can’t seem to see what I’m doing well enough without burning my eyebrows off :ROFL: .  The little soldering I need to do is usually substituted with Locktite.  :ThumbsUp:
Hi Craig, thank you very much.
Waiting for the next steps coming at your running project.
As mentioned before, I like the clutch you have made there.
« Reply #413 on: March 09, 2021, 11:34:46 AM »
Hi everybody,
here the place where the long coolant return pipe should find its new home.
After some fiddling around with all the little challenges here, everything is fixed now.
« Reply #414 on: March 09, 2021, 04:26:00 PM »
Wow! That looks great, Achim!  The pipework is all so tidy, the paint job so neat - the whole ensemble looks wonderful!  :popcorn:
Offline sid pileski
« Reply #415 on: March 09, 2021, 04:33:36 PM »
Looking very nice!
What more do you have to do for a test run??
Sid
Online Dave Otto
« Reply #416 on: March 10, 2021, 01:15:59 AM »
Hi Achim
I'm still following along and enjoying your great progress!
« Reply #417 on: March 10, 2021, 02:47:19 AM »
 :Love:
 :drinking-41:
« Reply #418 on: March 10, 2021, 02:21:43 PM »
Thanks Kim, waiting for your next progress also. Enjoy your retirement.
« Reply #419 on: March 10, 2021, 02:24:26 PM »
Hi Achim
Hi Dave, thanks, more time more progerss.
