Help! > Mistakes, muckups, and dangerous behaviour
Making My First Gear
steamer:
I'm glad the spreadsheet is helping Don! I'm going to need to use it myself when I put the 60 hole circle in my SB pulley....
Definitly set that bugger back up and cut some more teeth ....nothing to lose, and you'll get a better feel for the whole set up.
Maryak:
Don,
Sorry to read about your Oops. If I am looking at things correctly, you are starting the cut from the back of the blank, so it's difficult to see what's going on until it's too late.
May I suggest you either turn the cutter 180 and reverse the rotation, or start the cut from the other side of the blank, or put the RT on the other end of the mill table.
Edit:
Lastly, prove your indexing.
Hope this helps
Best Regards
Don1966:
Thanks I will finish the gear for a test run. And I do have a habit of turning the dial by the collar instead of the crank and it is a slip collar. I also have a video by Swarfrat on the RT. this is how I learn to read minutes and seconds.
Don1966:
Thanks Bob I will try that.
tel:
--- Quote from: Don1966 on September 20, 2012, 12:53:50 AM ---Thanks Dave and Tel I hope the next one goes a lot better. I just have to keep focused on what I am doing. Dave the spreadsheet you gave me is great. I still struggle with setting the seconds they are so close. Hope next week I can try again. The is the 34 tooth gear for metric conversion of my Myford.
--- End quote ---
There's 99% of gear cutting success right there.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
